How do you program the Garage door button?
Old 02-24-2011, 03:15 PM
iceman-kimster's Avatar
2006 E55
My car didn't come with a manual so that don't help... And I went to the dealership and guys in service weren't sure how to get mine to work.
I live in a condo building and the way we open the main gate is with garage door opener that everyone gets... Is not a normal garge door opener, this thing is small and it goes on my keychain. The name that I see on they keychain and on the units that operate the main gate is "SKG".
I tried holding one of the buttons on the mirror while pressing the controll remote but it didnt work.
Does anyone know what do I need to do in order to make this work?
Old 02-24-2011, 03:22 PM
MrKool's Avatar
I think you have to program BOTH your controller (button in your car) AND the opener (which in your case, you might not have control over) simultaneously.
At least this is how I did my home garage opener. There is a learn button on the opener that when pushed, listens for signals coming from the controller (buttons in the car).
Old 02-24-2011, 03:47 PM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
There are three buttons on the mirror. My first button didn't work so I programmed the second. Switch on ignition. Press and hold the two outer signal buttons and release them when the indicator lamp begins to flash. Do not hold for longer than 30 seconds. This erases any previous settings and initalizes the memory.
Hold the end of the transmitter, 2-5 inches away, while keeping the indicator lamp in view. Using both hands, press and holdthe transmitter AND THE DESIRED BUTTON TO BE PROGRAMMED. The indicator lamp will begin to flash from slow to fast, release both buttons. Press the button you just programmed and observe the lamp. If the lamp remains lit, programming is complete.
Some remotes only transmit or quit after two seconds. Therefore, you should press and hold for two seconds, release then press and hold for two seconds and release. Repeat this step until the frequency has been learned. Upon successful training, the indicaotr lamp will flash slowly then rapidly after several seconds.
The unit is only able to program frequencies between 280-390 MHz. Check the remote for the frequency.
Hope this helps. Good luck.
Old 02-24-2011, 03:50 PM
MrKool's Avatar
ANNDD..I stand corrected. I was thinking of my lexus. On the benz, you do have to do it with the opener.
Old 02-24-2011, 03:54 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
If the gate has rolling code you will need more information.
www.youtube.com/watch?v=sbRUjmLA9ig
Old 02-24-2011, 04:11 PM
lawguy's Avatar
Formerly: 2007 e63; 2012 GL450
You can find a .pdf of the manual online.
Old 02-24-2011, 05:24 PM
03'55AMG's Avatar
AMG
Call roadside, they have a machine with instictions, mine wouldn't work at all with the manuals instructions. Found out I have a rolling code and the automated thing had me ip and running in less than 2 minutes
Old 02-24-2011, 05:37 PM
chawkins2001's Avatar
2006 E55 AMG
Subscribing
Old 02-24-2011, 05:48 PM
MrKool's Avatar
i have the e55 manual in pdf btw, if somebody needs it. I can email.
Old 02-25-2011, 09:33 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
http://www.mbusa.com/vcm/MB/DigitalA...tic_e55amg.pdf
Old 04-28-2022, 11:32 AM
Tomcat SL's Avatar
2004 SL55 AMG
Okay, I did this years ago and it worked...now I am at my new house and cannot get the 2004 SL55 to work with my current Chamberlain garage door openers.
For some reason, I cannot get the button I want to make the LED flash fast...it stays slow (about once a second)???
Old 05-07-2022, 09:12 AM
Tomcat SL's Avatar
2004 SL55 AMG
On newer Chamberlain door openers (and a 2004 SL55) this worked like a champ:
Liftmaster 855lm Chamberlain OEM Homelink Compatibility Bridge...
Quick Reply: How do you program the Garage door button?
