Audio System Enhancement Options?
Old 12-25-2011, 01:40 PM
AMGPilot's Avatar
2004 E55
Originally Posted by t-bone
How do you navigate the new COMAND since the W211 doesn't have the control wheel/toggle in the center console area? I'm sure you can navigate it but just curious how.
Thanks!
By using the direction pad, and okay on the head unit.
For some reason there is a rumor that you have to use the control wheel to make this system work and that is simple not true, you do it just like the stock comand
Old 12-25-2011, 02:55 PM
Former Vendor of MBWorld
Cartronics's Avatar
05 CL65 AMG, 07 Ferrari F430, 03 Range Rover HSE
For those that don't know, we have many of the supplies to change or add to the factory system. We are the north American distributor for mObridge (as of November 2011) too.
Old 12-26-2011, 01:21 AM
nardeezy@yahoo.'s Avatar
E63 AMG
Originally Posted by goatfarmer1970
A Mobridge ipod and Bluetooth system is a pretty good starting point if you want to retain factory head unit, and it allows for the use of the factory steering wheel buttons, integrates with MOST, etc. Then I bought a JL audio 500/5 amp which has 100x2 for the front, 25x2 for the rear, and 250x1 for the sub, used new front speakers, and left the fatory rear speakers and sub. Oh, and an Audsion Bit Ten EQ-type-thing that allows for the removal of the factory settings. It actually sounds pretty good, is a clean design and cost $2800 installed with Dynamat in the doors, etc.
This maybe something I'd be interested in doing. Did you just replace the factory amp with the JL amp? If so was it a direct replacement or did you need to make mod's? What's the Audison Bit Ten? What would I need that and how would it look installed?
Old 12-26-2011, 01:47 AM
aghakauve's Avatar
GLC63s, W222 S63, W223 S580
I want a sub like a 10" JL with an amp.. But idk what route to go if anyone wants to help me with that!
Old 12-26-2011, 03:56 AM
E63 AMG
Did some research. If you want to maintain the factory Comand, at minimum, I believe you'll need a new subwoofer, multi-channel amplifier and audition bit 1 or 10 (or equivalent). I'm not sure how much modification will be needed to the vehicle. I guess it all depends on the footprint of the replacement amplifier and converter.
Old 12-26-2011, 04:18 AM
AMGPilot's Avatar
2004 E55
You will also need something like a mob ridge to drive the new amp. All audio in the car is on the most ring which is optical. The only audio that is moved about with copper wires is post amp to the speakers
Old 12-26-2011, 04:28 AM
  #32
mikey33's Avatar
2004 E55, 1997 E320 "Sold"
Hey! Check out my audio install below, it sounds like you are trying to do the same thing I did.
https://mbworld.org/forums/w211-amg/...more-bass.html
Old 12-26-2011, 11:35 AM
  #33
aghakauve's Avatar
Yep basically something like that. Hows the bass? Do you hear any rattling from outside?
Old 12-26-2011, 11:55 AM
  #34
SterlingE55's Avatar
2006 E55, 2012 Jeep SRT, 2008 G37s 6MT (The Mrs.), 2005 Explorer
I'll take some pics of the box I built when I get back to my car this week. I removed the factory sub and built a box that fires up through the factory hole against the back glass. It's nice and clean and bolts to the rear shelf so it stays out of the way. I've got a 10" type R in it powered by a clarion amp. I'm going to switch to all JL eventually. This was just what I had laying around and it sounds way better than stock.
Old 12-26-2011, 12:22 PM
  #35
E63 AMG
Shouldn't need mob ridge unless u want to integrate iPod or BT? I have a mobrodge iPod/BT unit in my Cayenne and it's only for that. If u only want to add a 10" sub to enhance sound quality u only need a subwoofer, audison bit one and new amplifier. The audison will take care of the audio processing for the Comand.
Old 12-26-2011, 12:37 PM
  #36
AMGPilot's Avatar
2004 E55
There is a mObridge that converts audio directly from the MOST ring to analog for external amps
Old 12-26-2011, 12:41 PM
  #37
E63 AMG
Wow. So in addition to a CleanSweep (or equivalent), you will also need a mobridge MOST converter (or equivalent)? Two devices after the head unit until it goes to the aftermarket amp?
Old 12-26-2011, 12:50 PM
  #38
AMGPilot's Avatar
2004 E55
To do it right yes. And by then you're getting into NTG 2.5 conversion costs
Old 12-27-2011, 02:16 AM
  #39
6spdcoupe's Avatar
'14 F15 M, '06 E55, '20 Highlander, '18 M550
Swapping out the deck is the much easier, less costly approach if upgrading All of the audio.
Old 12-27-2011, 03:01 AM
  #40
johnbill1236's Avatar
mbw
Carefull!!!
I just got my car back from respected audio shop and now my keyless start doesn't work. I had amps and focal speakers installed.
The dash says " key not recognized"
I've tried everything to fix
Old 12-27-2011, 03:03 AM
  #41
AMGPilot's Avatar
2004 E55
Originally Posted by johnbill1236
Carefull!!!I just got my car back from respected audio shop and now my keyless start doesn't work. I had amps and focal speakers installed.
That's one of the reason I wanted to stay with factory.
Old 12-27-2011, 03:14 AM
  #42
6spdcoupe's Avatar
Carefull!!!
The question is ...why are YOU trying to fix it ? Is that not THEIR responsibility ? Any 'respected' shop should and would ..
Old 12-27-2011, 03:16 AM
  #43
6spdcoupe's Avatar
After a few dozen of em, it becomes Very easy. Actually these cars are as simple as doing the majority of the more common Toyotas, Hondas,etc..
Old 12-27-2011, 10:18 AM
  #44
AZBENZ-CTSV's Avatar
PORSCHE PANAMERA TURBO LAMBORGHINI GALLARDO SL600 E55 BRABUS*SOLD*
Originally Posted by Fly by night
Carefull!!!
Did you try disconnecting the battery?
changing battery in remote?
Old 12-27-2011, 12:25 PM
  #45
aghakauve's Avatar
Defiantly take some pictures. I want something that wont take up too much trunk space and looks clean as well, I was going to do a similar set up like Mikey33 but I'm open to ideas.
Old 01-08-2012, 01:49 PM
  #46
clk63DK's Avatar
CLK 63 amg
Hejsan,
Where did you go to get it installed?
And did they fix it now?
Chris
Carefull!!!
Old 01-09-2012, 01:58 PM
  #47
Busta Riles's Avatar
1969 280S, 1991 300E
If you're looking for bass in an E55, go with a 12" instead of a 10".
I tried a 10 in the trunk of my E55, but the car is so quiet that the sound wasn't getting into the cabin...i switched it out for a 12 and it was perfect.
Old 01-10-2012, 12:05 AM
  #48
e55amg00's Avatar
2017 Alfa Giulia gone, 2004 e55 amg gone,2014 E550 coupe white,2010 E550 coupe white, 2018 giulia ti
Smile
Originally Posted by AKnight55
So Im wondering if anyone has just replaced the factory speaker with aftermarket and run them off the factory amp? Or is that even possible? I know to get the best sound I would need to replace the amps, but I don't want to spend a lot Andy hack up the factory system. Thanks for any help
The amps in the '03-06 E's are horrible. I replaced mine with a factory '08 harmon kardon amp and it made a helluva difference. The amps have different part numbers. The older style has heat sinks and new style has an integrated fan. Speakers were left alone and I'm thoroughly satisfied.
Old 01-25-2012, 05:47 PM
  #49
starbrite's Avatar
2004 E320
You can really hear the difference in the same brand amps in a car environment? That's very surprising to me, if so.
Quick Reply: Audio System Enhancement Options?
