*-*-* B.I.P Trunk Tank Kits, limited run in time for the Summer*-*-*
Former Vendor of MBWorld
E55 AMG on Ethanol-Meth; 600rwhp BMW M5
Video
http://s138.photobucket.com/user/cha...039-1.mp4.html
Kits come 100% complete with:
- 3/4 hosing
- stainless fittings
- Bilge 2000 in Tank Pump
craig.hawkins@buckhead-imports.com
404-641-7595
$599 plus ship
no, you can tuck them so they they are not visible at all.
If you look under H's E55(black06c230), you cannot even tell he has a trunk tank by looking under the car.
How do you think this trunk tank with stock HE/supercharger cooling will work? Is the spare taken out?
So no spare with this right?
Also I have no aftermarket He, any real benefit with this?
Yes sir, no spare once you install the tank. Adding a tank with the stock HE is better than just adding a aftermarket HE. You could route it the following way for optimal results:
Trunk tank with bilge pump》front intercooler pump》intercooler》heat exchanger》back to the trunk tank.
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
Some pics of my tank install.
Trunk, I know a little dirty:
Under floor installed:
Hole for lines:
Lines ran under the plastic under cover:
From a distance:
Drain hole/tube:
Hole for lines:
From a distance:
Drain hole/tube:
