LOL 2 years ago I wanted to drive my E55 like Chris Harris
I'm tempted to pick up some Sumomito HTR's for 480 shipped and do a track day with extra tail action. Michelin PSS are a bit sticky/expensive to be kicking the back end out!
I love roasting tires
I know dyno mode is dangerous in a car with this much power if the person driving doesn't know what they're doing but if you want raw raw torque and power without ANY nannies it's the way to go. One thing though, I did go into limp mode a few times in dyno mode after some RAW driving, it would get stuck in 3rd gear until I turned off then back on. It happened a few times, didn't linger though.
PLATINUM SPONSOR
Nice Denrol and going up a mountian too.
As far as torque management with TC off or on and vs dyno mode, it varies between years/models. The 03 W211 will go totally out of control and roast the tires to the rims with TC off but the 06 w211 has more TM built in it seems . The CL55 and S55 also have a lot of TM built in and are hard to spin out of control . My new W212 has even more TM than any other model I have owned or driven but dyno mode is easy to activate.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
ESP off doesn't turn traction control off, it will still try to stop slides. I've turned off ESP and driven hard then put it into dyno mode and driven hard, dyno mode is COMPLETELY different. It doesn't hold the car back at all. I remember putting my foot to the floor from a standstill in dyno mode and I layed down VERY long 11s without even touching the brakes and there was smoke everywhere. ESP off doesn't let you off completely and it's bad to push the car because it uses the brakes to try to stop the wheelspin and so you roast and wear your brakes.
Ducati
How did you do that burnout with only ESP off??
I was certainly able to "drift" with ESP off only but for a full blown long set of 11s on the road, no way, it would start cutting in. Even when trying to get the rear loose in turns, it would loose it but it would "bring it back" in a way or not let it get too out of hand but with dyno mode, it just leaves and hands you the controls
Maybe the older cars are less invasive? The again, Denroll, your car is 06 so......
Yeah older TCU's are less invasive I believe.... Maybe Denroll has a TCU tune....?
Here was the aftermath... similar to Denroll's
My car is an 04, no TCU tune.
