what is the best way to remove 16mm top motor mount bolt....
what is the best way to remove 16mm top motor mount bolt?
so ... trying to get these motor mounts out but this 16mm top bolt is in there good. minimal room to break the bolt... hoping to do this with out removing exhaust manifold or alternator via sway bar.
To do the job safely and by the book---the book requires the removal of the exhaust system-------may you be blessed with 24 raisins!!
I slapped the spanner on and tried to have my hand in between the spanner and I think the chassis or something to lever off. Mine weren't overly tight though and came away easy enough.
I have one of those offset tools mentioned, and I struggled before I bought it, but as soon as I got it, the job took 30 minutes tops. You can find them really cheap on ebay, like 10 or 15 bucks.
nevermind used a ratchet wrench , and most of my patience, luckily once they were loose you could undo by hand. the drivers side one is the worst!
thanks again fellas, 2 new correct motor mounts and trans mount and she feels like a new car again.
