W212 2011 E63 AMG Wheel Spacers
I have searched and searched for threads regarding my question. I found some information but nothing in solid clad.
I am looking to get spacers for my OEM 19in double 5 spoke wheels. I want a more flush look for an aggressive stance from the rear. Currently, it's not aggressive whatsoever with the factory offset.
I've read in multiple areas that people are using hub centric H&R spacers. Anywhere from 5-10mm in the front and 10-20mm in the rear. I am not looking to pull them out so far that it looks funky, just enough to sit flush with the fender. I'm also stock ride height so there should be no issues regarding fender rubbing.
Now, I went to H&R's website and they do not seem to have a spacer for our car (Year 2011) and I do not want to get eBay spacers. To me spacers are an important deal being that the studs are holding the wheels on and if a stud breaks from cheap quality manufacturing it could potentially be a dangerous hazard.
My question is where can I find a good quality spacer that can do the job?
I'm also a bit concerned with vibrations, I've heard mixed things about this that some vibrate and some don't.
I will be posting pictures of the final outcome as soon as I get some insight.
look at the bottom of the first page of this thread.
https://mbworld.org/forums/w212-amg/...ro-12-e63.html
As vcci said, look at the bottom of the first page for pics.
jmontes1214 (11-30-2019)
I purchased a set of H&R front 10mm/rear 20mm hub centric spacers from ecs tuning. These spacers are not listed in the "fits" section but it will work for your car. I installed the spacers last Friday and felt no vibrations what so ever. However, I am selling my spacers if you are interested. The reason for selling, I am getting a new set of wheels and decided to use the stock wheels for occasional winter duty. The spacers are listed in the for sale section and will include the extended bolts. Feel free to contact me if you have further questions.
What would you recommend if you had to go back and change your specs? I hear a lot of people steer away from spacers; however, I cannot deal how whimsy the rear looks from the wheels having such poor offset. If you could send me some more pics of the wheels on your car with the spacers that may help me better my decision.
I have the same wheels as you; however, stock ride height.
No problem. Glad to help.
The front/rear tires sit flush to the fenders without sticking out. This setup was also recommended by ecs tuning. As far as rubbing, I did notice the front was slightly rubbing over bumps during spirited driving (updated my build thread with this info). Having said this, I was planning on correcting the rubbing issue by re-adjusting the ride height and getting an alignment done (probably alignment is off from lowering). If I were to do it all over again, I would stick to the same size spacers for the flush look especially if I'm not lowered.
Using spacers might be frowned upon here, but I personally had no issues running spacers on my Audi for years as well as my buddy with a BMW. Generally speaking, the use of the spacers are more common with BMW/Audi compared to MB. Just be sure to use good quality spacers (hub centric to reduce stress on the bolts/extended bolts) and H&R is a reputable company.
I can take additional pics and email them to you - what's your email address?
The front/rear tires sit flush to the fenders without sticking out. This setup was also recommended by ecs tuning. As far as rubbing, I did notice the front was slightly rubbing over bumps during spirited driving (updated my build thread with this info). Having said this, I was planning on correcting the rubbing issue by re-adjusting the ride height and getting an alignment (probably alignment is off from lowering). If I were to do it all over again, I would stick to the same size spacers for the flush look especially if I'm not lowered.
Appreciate the pics & advice. Car looks excellent! Where did you buy the spacers from? Also, any rubbing when turning or hitting bumps?
spacers are from a distributor in canada for H&R.
make sure you get the right bolts. i believe they need to be 14 mm. they sent me 12 mm first.
nah, no rubbing. no worries about that. not on stock wheels. maybe if you went 20 mm in the rear?
but i woudlnt do 20. 15 is nice and aggressive.
its a good mod. makes the car look so much better. of course you have to do the lowering as well. my lowering kit was super cheap. H&R springs for front and links for the rear sold together for like $400. links are adjustable too.
