Wagon Offset Question (yes another one) - range of acceptable fitments
Old 01-23-2017, 05:23 PM
ajs76's Avatar
2014 E63 Wagon
Hi guys,
I just searched through a ton of threads on this, but instead of a "yo do my 335 wide 22's fit?" I wanted to get a range of fitments from some experts so I know how to shop the daunting used market
Stock sizes for 2014 E63 Wagon:
Front wheel offset 37 mm
Rear wheel offset 52 mm
Bolt pattern: 5x112
front 255/35 ZR 19 XL
rear 285/30 ZR 19 XL
"Ideal" Size for 19's according to someone smarter than me. i.e- what you would buy if you had them made for you.
19x9 et 30 255/35/19
19x10.5 et 46 295/30/19
Is this valid?
Range of acceptable offsets that would work for the stock tire sizes? (This is my real question)
19x9 - 255/35 - Offset?
19x9.5 - 285/30 - Offset?
I've seen some people say you can do low 40's on the fronts, but I've seen nothing definitive. Is this voodoo math? Why nothing concrete.
mj_39 (01-23-2017)
Old 01-23-2017, 05:54 PM
skark_burmer's Avatar
2012 E63 Funwagon
I am running 295/30 rear and 265/35 front and like the way they look/fit on the OEM rims.
I wont get into rubbing and all that cause i have a '12 wagon so my fittment comments likely wont apply to a '14.
Old 01-23-2017, 06:42 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
In my opinion those "ideal" specs you quoted are pretty spot on. There's room to play but those are a good target.
Old 01-30-2017, 11:44 PM
noodleman's Avatar
2014 E63S Wagon
You should make sure the difference in height from the rear wheel isn't too far off from the fronts, or else your 4matic is going to complain (i'm assuming your e wagon is 4matic).
Old 01-31-2017, 03:42 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
If you plan to lower your car, this will rub. You'd want 19x10.5 ET49 for 295s. Et46 would be ok for 19x9 on 295.
ajs76 (01-31-2017)
Quick Reply: Wagon Offset Question (yes another one) - range of acceptable fitments
