Brabus Once Stuffed a Big V12 In an E-class And We Cant Love It Enough
Brabus gave 10 people the chance to have more than 1,000 lb/ft of torque in their E-class with the wild E V12.
Anyone who’s ever experienced a Mercedes turbo V12 knows they are immensely powerful machines. Direct from Mercedes, they’ll pin your kidneys to your spine with every press of the throttle. But if ‘a lot’ is not enough, Brabus tunes them to absurd power levels. But Mercedes only offered the V12s in a select number of cars.
Brabus solved that problem by somehow finding room for the V12 in a W212 E-class. They call it the E V12, and it’s even more powerful than a standard AMG V12. You didn’t ask for 788 horsepower in your E-class, but here you go anyway. Want tires to last 20 minutes? You’ll be able to accomplish that with 1,047 lb/ft of torque. We found this one on ClassicDriver, and it’s quite a departure from a standard E63 AMG.
Starting with a 6.3 liter V12, Brabus worked their magic to create those power numbers. But we feel more magic had to be done in order to get the thing to even fit inside a W212 chassis. It’s already a tight fit in the bigger S class, and long-hooded SL roadsters.
Keen eyed observers will see the front radiator support has been ditched in order to accomodate the V12’s front accessory drive system. By that alone, we can only assume the extensive work to cut up a car, and yet make it stronger than before to handle the loads of a big V12.
Inside the car, just about every surface has been changed to high qualify leather, Alcantara or carbon fiber. A special wrapped steering wheel contains Brabus badging, along with carbon fiber. Badges can also be found on the seatbacksm, and a special “one of ten” EV12 badge lets you know how special the car is.
Did you think we weren’t going to mention the body kit? Think again. While Brabus has typically come up with some great looking subtle modifications, the side skirts on the rear wheels will definitely be a love/hate kind of look. But, apparently they do serve a function. Wind tunnel tested, they reduce lift at front and rear, which is a good thing when you’re travelling on the sharp side of 200 miles per hour.
Photos: Classic Driver
You must be logged in to post a comment.
