2009 Mercedes Benz C300 vs. 2009 Mercedes Benz CLK350
A new 2009 Mercedes Benz C300 will cost you around $30,000. Cost and value have bonded well in the C Class, attracting new Mercedes owners in recent years – 60% were buying one for the first time in 2007. The CLK class developed as a progression from the C Class. Is the new 2009 CLK350, worth the extra cost of progress?
![2009 clk350 cdc.jpg](https://mbworld.org/2009%20clk350%20cdc.jpg)
One valuable detail in today’s automobile market: mpg. The 2009
Mercedes Benz C300 ranges from the low-20’s in the city to the
high-20’s on the open road, whether this is a good thing or a bad thing
depends on which vehicle/class you are researching. Another thing:
forget that Baby Benz stuff, it is spacious enough to fit you, your
family, and luggage. A seating capacity of five calls for some “family
car” talk.
The 2009 Mercedes Benz CLK350 is dubbed a 2+2 car. With many vehicles,
this 2+2 seating may equal four passengers, but the second two will
need to be kids or patient adults. This is not the case with the
CLK350; bring some friends and go for a ride. With 268 bhp, you and your friends can get where you need to go on time, though the 228 bhp C300 should not be too far behind either.
2008 Mercedes Benz CLK Model Line Overview | |
Model lineup: | Mercedes-Benz CLK350 Coupe ($46,450); CLK350 Cabriolet ($54,500); CLK550 Coupe ($55,150); CLK550 Cabriolet ($63,200); CLK63 AMG Cabriolet ($89,500); CLK63 AMG Black Series ($135,000) |
Engines: | 268-hp 3.5-liter dohc 24-valveV6; 382-hp 5.5-liter dohc 32-valve V8; 475-hp 6.3-liter dohc 32-valve V8 |
Transmissions: | 7-speed automatic |
Safety equipment (standard): | dual two-stage front-impact airbags; front passenger side-impact torso airbags (coupe) or head and torso airbags (convertible); curtain-style, full cabin head protection airbags (coupe); automatic-deploying roll bars (cabriolet); Tele Aid emergency communication; antilock brakes with brake assist; electronic stability program |
Safety equipment (optional): | rear passenger side-impact airbags ($390) |
Basic warranty: | 4 years/50,000 miles |
Assembled in: | Osnabrueck, Germany |
Specifications As Tested | |
Model tested (MSRP): | Mercedes-Benz CLK350 Coupe ($46,450) |
Standard equipment: | dual-zone automatic climate control with pollen and dust filter; leather upholstery; 10-way power-adjustable front seats; power tilt/telescope steering wheel; 3-setting memory for front seats, steering wheel and exterior mirrors; 6-speaker AM/FM/CD stereo; one-touch up/down power windows; keyless remote locking; trip computer |
Options as tested (MSRP): | Sport Appearance Package ($490) includes sport suspension, cross-drilled brake rotors and ten-spoke alloy wheels; heated front seats ($700) |
Destination charge: | ($875) |
Gas guzzler tax: | N/A |
Price as tested (MSRP): | $48,415 |
Layout: | rear-wheel drive |
Engine: | 3.5-liter dohc 24-valve V6 |
Horsepower (hp @ rpm): | 268 @ 6000 |
Torque (lb.-ft. @ rpm): | 258 @ 2400 |
Transmission: | 7-speed TouchShift automatic |
EPA fuel economy, city/hwy: | 19/28 mpg |
Wheelbase: | 106.9 in. |
Length/width/height: | 183.2/68.5/55.4 in. |
Track, f/r: | 58.9/58.0 in. |
Turning circle: | 35.3 ft. |
Seating capacity: | 4 |
Head/hip/leg room, f: | 37.1/53.7/42.0 in. |
Head/hip/leg room, m: | N/A |
Head/hip/leg room, r: | 35.8/45.9/33.0 in. |
Cargo volume: | 10.4 cu. ft. |
Payload: | N/A |
Towing capacity: | N/A |
Suspension, f: | independent three-link, coil springs, gas-pressurized shocks, stabilizer bar |
Suspension, r: | independent five-link, coil springs, gas-pressurized shocks, stabilizer bar |
Ground clearance: | 3585 in. |
Curb weight: | N/A |
Tires: | 225/45ZR17 front; 245/40ZR17 rear |
Brakes, f/r: | vented disc/disc with ABS and Brake Assist |
Fuel capacity: | 16.4 gal. |
2008 C-Class Model Line Overview | |
Model lineup: | Mercedes-Benz C300; C350 |
Engines: | 228-hp 2.8-liter V6; 268-hp 3.5-liter V6 |
Transmissions: | 7-speed automatic; 6-speed manual |
Safety equipment (standard): | frontal airbags, side-impact airbags, curtain airbags; electronic stability control, traction control, ABS, EBD, Pre-Safe |
Safety equipment (optional): | none |
Assembled in: | Sindelfingen, Germany |
Model tested (MSRP): | Mercedes-Benz C350 Sport |
Standard equipment: | N/A |
Options as tested (MSRP): | N/A |
Destination charge: | N/A |
Price as tested (MSRP): | N/A |
Transmission: | 7-speed automatic |
EPA fuel economy, city/hwy: | N/A |
Wheelbase: | 108.7 in. |
Length/width/height: | 180.4/69.7/57.0 in. |
Track, f/r: | 60.4/60.5 in. |
Turning circle: | 35.4 ft. |
Seating capacity: | 5 |
Head/hip/leg room, f: | 37.1/52.3/41.7 in. |
Head/hip/leg room, r: | 36.9/54.9/33.4 in. |
Cargo volume: | 17.6 cu. ft. |
Payload: | N/A |
Suspension, f: | independent, coil springs, gas struts, stabilizer bar |
Suspension, r: | independent. five-link with coil springs, gas shocks, stabilizer bar |
Ground clearance: | N/A |
Curb weight: | 3498 lbs. |
Tires: | P225/40ZR-17 front; P245/40ZR-17 rear |
Brakes, f/r: | disc/disc with ABS, EBD, Brake Assist |
Fuel capacity: | 17.4 gal. |
