190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1987 - 190D... shakes on freeway
Old Jul 26, 2005 | 03:17 AM
Newbie2MB's Avatar
When the speed hits like 60 mph, the car starts shaking in a weird way... anyone have any idea what could cause this and what I could do to fix this problem?
Old Jul 26, 2005 | 12:59 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Check 1) wheel balance carefully, Mercedes are particulary sensitive to balancing, so find a good shop to do the check; 2) have the front suspension looked at, particularly ball joints and tie rod ends; 3) the drive shaft balance can also cause shaking at speed.
Old Jul 26, 2005 | 04:36 PM
Newbie2MB's Avatar
thanks a lot... i'll tell my dad to go check those things out somewhere
Old Jul 26, 2005 | 04:39 PM
Justinius7's Avatar
possibly a flat spot or warped tire or a busted belt internally.
my 190 does the same, need to replace the right rear tire.
Old Jul 26, 2005 | 11:28 PM
Nandgopal's Avatar
Mercedes Benz 230e, 124
Shakes
While you are at the shop check for engine bedding and the gear box mounting, The engine bedding being oil filled, it is possible that one of them have become soft and the the other collapsed.
Old Jul 30, 2005 | 02:20 PM
Dan's 1993 190E's Avatar
1993 190E 2.3
Drive shaft flex discs
At the front and back of the drive shaft there are two flex discs (bushings that look like huge washers with about 6 bolts going through them). If you go to have your drive shaft checked out you might want to ask the mechanic to check them. My 77 280CE had a vibration at around the same speed, these discs can wear out and are probably the most likely cause of an imbalance in the drive shaft area. Like any other bushing, they get a bit dry rotted with age.
Dan
Actually, you should remove and retorque the 6 bolts at each end. Even if the disc appears to be in good shape, if the bolts aren't torqued right it could cause problems. It would also give you (or your mechanic) a better look at them.
