190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Help
Old Sep 3, 2005 | 11:18 AM
Benz Lover's Avatar
1991 190e 2.6
Help
I am trying to determine what the name of a part is. It on a 91 190e 2.6, if I'm standing in front of the engine its on the left hand side near the area where the coolant overflow and washer fluid resevior are. Theres a hose coming out of the fire wall to the part then theres a hose the goes to the water pump...whats the name of the part that sits there? It seems to be leaking anti- frezze!
Old Sep 3, 2005 | 02:22 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Just a suggestion, try to make your thread title a bit more descriptive than "Help"
From the description, what you are describing is the auxillary coolant pump. The small electrical pump drives heated coolant to the heater core to provide the heat source for cabin heat.
Old Sep 4, 2005 | 12:05 AM
azmoto's Avatar
'91 190E 2.6L
I believe it is called an expansion tank, If you mean the part with the radiator cap just behind the washer fluid tank. It is a clear plastic so that you can see the fluid level.
Old Sep 6, 2005 | 08:30 AM
Benz Lover's Avatar
1991 190e 2.6
It's not the expansion tank or overflow(same thing) it actually sits low in the engine area..It sounds more like the auxillary pump since theres a hose thats going into the firewall...Thanks
Old Sep 6, 2005 | 08:31 AM
Benz Lover's Avatar
1991 190e 2.6
Cool I just didnt know what to put in the title...next time I'll try to think of something creative!
Old Sep 6, 2005 | 08:34 AM
Benz Lover's Avatar
1991 190e 2.6
Just to be sure is there any picture of that area online?? nevermind found one!!
Old Sep 6, 2005 | 11:03 AM
Benz Lover's Avatar
1991 190e 2.6
Is this what some people call a aux. coolant pump or is the aux.water pump??
Its what is in the red box!!
Thanks!!
Old Sep 7, 2005 | 11:33 PM
azmoto's Avatar
'91 190E 2.6L
umm the overflow tank is whats connected to the end of that hose that runs from your expansion tank right below the cap (its insulated i think), you cannot see it is in the wheel well somewhere.
Old Sep 8, 2005 | 11:17 AM
Benz Lover's Avatar
1991 190e 2.6
Its not the expansion tank , I already bought the part and replaced it, its called the auxiallary water pump.
Thanks for your assistance!
