Oil leak problem- need your advise
190E2.6
i recently got a 92 190E,2.6,auto,with 120kkilo/70kmiles from a family friend,
the car is running ok, just couple of problems need to figue out:
1. oil leak
2. the cooling fluid is dirty and oil-mixed-like
(i took some photoes of this engine and i could email to you)
3. is the radio antenna suppose be powered?
any suggestion?
1. oil leak
any suggestion?
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
1. oil leak
1. oil leak
any suggestion?
any suggestion?
190E2.6
thanks, MTI.
PS... a local machanic quote me $500labour + parts to change the headgasket for me, (in his backyard) , do you think this is a good offer? he said i need to change the gasket right away.
1985 190e 2.3l
thanks, MTI.
1 Post
The price, even without parts (you'll need to flush your cooling system too and I would change the oil), sound decent for the amount of work. Working on the M103 engine in a W201 chassis isn't as easy as the 4 cylinder. It's pretty cramped in there. The radiator and radiator support has to come out. While the front part of the engine is being disassembled, I would seriously consider installing new timing chain guides (plastic); and a new chain tensioner. If you had the time, having the head dipped to clean it off might be worth it depending on its current condition.
190E2.6
MTI, is this what i need? -Cylinder Head Gasket Set-(attaching link is the parts i plan to order)
http://69.0.158.19/live/A801027058REI.JPG
or the crankcase gasket set?
http://69.0.158.19/live/A802026401GOE.JPG
or just valve cover gasket?
http://69.0.158.19/live/A803025632BRU.JPG
thanks
thanks
1 Post
You'll need all three and more, the valve cover gasket, the head gasket and the front timing chain cover gasket. You'll also need the gasket for the water pump if it's not included with the timing chain cover set.
Although the job can be done without removing them from the head, some mechanics do remove the intake and exhaust manifolds rather than disconnecting at the downpipes and fuel system. If the manifolds are removed, it's a better idea to change out the gaskets on them too.
Check the serpentine belt too.
