Need some advice
the car. 2 owner in outstanding condition. Also is there a trunk light?
Thanks for any help.
2007 is going to be a great year!!
Larry
2) The coolant level sensor is the round plugged in device located at the bottom of the overflow resevoir, give that a check and/or cleaning.
3) No heat from the floor vents might be signs that the vacuum valve for the duct has failed in the shut mode. It could be the controller or the vacuum line to the valve. If you're getting heat from the front window defroster and the left and right dash vents, then the heater core is getting coolant from the radiator. There's never any heated air from the center console vents . . . unless the system is broken.
4) Yes, there is a trunk light, it's just a bare bulb located in a cutout in the center of the trunk lid closer to the latch mechanism.
