Overheat?
So its not really over heatign as much as its getting really hot.
It runs between 80c-100c with the AC off.
My problem is, when I let it sit for a while, exspecially if im running the AC It goes up to 120c+
I do not know what the cause of this is. My AC fans come on, but only when my car gets to a certian temp, 110c.
Is this normal?
I had to replace the thermostat on my 190 about 6 months ago.
80 to 100C is fine.
Forget the a/c is on. I just put a 167c thermo in it. Im sitting at TacoBell drivethru, car gets over 100c. I have fluid in it. As soon as I start to drive again, it starts to go down, or if i put it in nutruel and rev it up to 3k or so.
My clutch fan spins all the time, it makes mroe noise when the car start to get over 100c though. Thats with the AC off.
Im going to take it to my mechanic and have him look at it this coming up sat. First week of every month (Im early this month, 2 oil changes in one month
), I get an oil change, so while its there im having a few things looked at. It idles kidna rough, its getting hotAlso, kidna random but when I have the air on, and im driving, sometimes when the car shifts, my belt sqweeks, and the compressor stops and my AC gets not so cold, then it wistles and the cold air comes back. kidna strange. I already replaced the belt, and that didnt fix anything. Someone said pulley tensioner, but the belt feels tight. I see what it is on sat i guess.
Thanks for the idea's ill have all that looked at on sat.
Im going to have the coolant flushed sat. and have my mechanic look at it. Ill let you guys knwo what it is sat. afternoon.
Thanks for all your help guys. Im going to write it all down and have them check everything. I hope it can get fixed sat.
That all sounds exactly how mine works. Im going in tomorrow morning at around 9. Ill let you know the problem when I get back.
Overheat problem, along with something about the ac problem im having, when the car shifts sometimes, the belt sqweeks when the ac's on, and then the air isnt cold anymore, then after some time, it whistles and gets cold again. They said it was pulley Tensioner? Or something. The guy game the part to get put on when we both have time. My threads are screwed up on the one I have. So maybe ill do that in two weeks or so and see if it helps.
He said the belt doesnt have enough tension on it run the water pump properly, and to keep enough tension on the compressor. we'll see.
My thermo stat is brand new, its a 167f. wich i think is only 78c. or so.
Im going to try to get the belt tensioner done soon, latest 2 weeks, and see if that fixes it.
Thanks everyone
Thanks everyone
When measuring temperature measure the radiator in all spots to check for warm/cold spots, also check the block temp in multiple places. My temps were higher with my old radiator and when I put a new one in the temps have since been great, used to get to 100 and pretty much stay there even when on the highway, I wired my aux fan to run at 100 instead of 110 since I no longer use my main fan due to an overpriced clutch and the amount of power it robs when active from the little 2.3. Anyhow get an IR thermometer and check that baby out. It was $50 at PepBoys for some peace of mind. Not to mention the fun uses around the house for the device.
