190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Starter Problem
Old Jun 15, 2007 | 10:29 PM
lovebenz's Avatar
190 E 1993 2.3
Starter Problem
starter on 190 e 1993 works fine some times but some time nothing going n at all ,,, butif bang it with some thing it starts up i dont know what it is mechenic says its pulling 300 ohms when it shud be around 85.. wants 700 to replace stuck
Old Jun 16, 2007 | 02:29 PM
Kynyption's Avatar
Euro 1985 190e 2.3-16vlv
Oh man, this again. Now i have dealt with this before, and i forget all the right terminology.
Basically what has happened is your pinion has gone bad. (Number 8) when you hit it hard it jams the pinion back where it needs to be, however when it doesn't work all the starter is doing is running the motor, not spinning any gears. Its a lot more complex and technical than that, but you get the just.
Get a starter off a junk car or a member parting their car, and replace it yourself.
Old Jun 17, 2007 | 02:22 PM
slk230red's Avatar
'93 190E 2.3, '01 SLK230, '71 Corvette LS5 Roadster
I just went through this in Jan. I purchased a rebuilt Bosch starter from Autozone for $110.00 with a lifetime warranty (we'll see how that works out). I replaced it myself...tight space, but do-able without removing any additional parts.
So far it has worked great!
Old Jun 17, 2007 | 07:04 PM
lovebenz's Avatar
190 E 1993 2.3
starter
ok i need just the basic steps or if ne thing i shud watch for im gonna change the starter my self ,,kinda save me time n hasstle , sorry hope im not leechin too much here
Old Jun 17, 2007 | 08:09 PM
slk230red's Avatar
Here is what I did to remove the starter from my '93 190E 2.3
1) Removed negative battery cable
2) Jacked up front end
3) Removed left front wheel
4) Turned steering wheel to far right
5) Removed cover/shield from under engine
6) Removed wiring from starter
7) Removed lower starter bolt
8) Removed upper starter bolt (this took longer to do since it was tight and in a tight space).
9) Removed starter by gently turning, twisting, and pulling out. It's tight, but it will come out without removing any other components.
*NOTE* Leave key in ignition and steering unlocked so you can move steering back and forth enough to allow clearance at pitman arm to remove and re-install starter. By doing this, nothing else has to be removed.
Good luck,
Dave
Old Jun 19, 2007 | 10:13 PM
lovebenz's Avatar
190 E 1993 2.3
starter thanks
starter
Old Jun 20, 2007 | 10:25 AM
slk230red's Avatar
starter
Does this mean you replaced your starter and everything went as planned?
Just curious...would like to hear an update how things went.
Dave
Old Jun 20, 2007 | 10:34 PM
lovebenz's Avatar
190 E 1993 2.3
starter
no have not done it yet but got up the courage to order one from auto zone so hopefully will be installing it this week end......
Old Jun 21, 2007 | 12:52 AM
slk230red's Avatar
Be sure to leave your steering unlocked so you can turn your wheels to get enough clearance to remove and re-install starter. Remember the position, angle and direction when you remove starter...It needs to go back in the same way due to very little clearance. It will be a challenge but you can do it!
Good luck,
Dave
Old Jul 7, 2007 | 10:26 PM
lovebenz's Avatar
190 E 1993 2.3
starter
Good luck,
Dave
hey back to the starter ok i tried taking off the engine cover bolt kept slipping so im trying to do it with it on talk about tight lol can i reach the upper bolt from the top next to the oil filter with a long ratchet ????
Old Aug 2, 2010 | 02:37 PM
Endat's Avatar
190E 2.6
I would also like to know the answer to this... I am having trouble removing the starter from my w201
