Combination Switch For Turn Signals
1998 Mercedes Benz E 320
I Have A 1992 190e And Putting The Stering Wheel Back Together Following An Ignition Switch Replacement. My Problem Is After All Is Installed, The Turn Signal Will Not Recover Or Reset Following A Turn. I Have A Cd Disk That Saws You Have To Reset The Cam Or Switch When Re Installing But No Further Info. What Is The Procedure To Make The Turn Signal Re Set Following A Turn? Or What Has To Be Done When Re Installing The Combination Switch?
