190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
No power to blower motor
Old Nov 22, 2007 | 12:15 AM
RickyBobby's Avatar
R350
Question No power to blower motor
Daughters 1990 190e 2.6 benz Vinny
I have checked the following,
blower motor with 12 volts applied running strong,blower resister no opens and tested with ohm meter, ground to blower motor with test light good, power wire to motor with speed switch in any position no power, but power at fuse though, checked switch with ohm meter good,brushes are halfway worn out.
is mas relay tyed to this some how? no abnormal noies or smells before it quit working.
Hayes book of No help yes i know... but it came with the car.
Im at a total loss as to where to test next please advise..!!! Starting to get quite cold here on the east cost.
Kind Regards: RickyBobby
Never Ever Junk a Good Parts Car Ever..!! Hide it underground if you have To
I Did Junked it is what i did
Old Aug 1, 2009 | 09:26 PM
Chiro's Avatar
1991 190E:1998 E320 4Matic wagon : 2000 E320 4Matic
Can't get blower motor housing off!?
HI RB
Sorry can't help you but hoping you could help me! I have a 1991 2.6 190E and squeaky blower motor that I am trying to get at . I have removed the wiper linkage and released clips on the side and top of the blower motor housing but can't pull the housing off..Are there clips on the bottom of the housing or any trick that you could share.
Chiro
