190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
190e throttle issue
Old Jan 9, 2008 | 02:29 PM
ccb_v2's Avatar
1986 300E 3.0 5-Speed
190e throttle issue
Ok new issue arose. after replacing plugs, wires, and injectors the car still has this issue. No matter at what RPM when the throttle is barely open and then opened more the car stumbles for a moment and then goes. This happens whether in motion or park. Any ideas where else to look to track this issue down would be greatly appreciated. Its a 1985 190E 2.3L.
Old Jan 9, 2008 | 03:18 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
First, remove the air cleaner housing and inspect for any obvious cable or vaccum line disconnects.
While the air cleaner is off, have a close look at the microswitch connection at the throttle attachment. It's the thin square black part with the spring loaded roller. Make sure that it's set upon the throttle correctly and not binding. You should also check that the vaccum adjuster (bowden cable) that runs from the throttle housing to the trans is adjusted properly.
Old Jan 9, 2008 | 04:12 PM
ccb_v2's Avatar
Ok, The microswitch (red) is working as it should and the throttle contacts it as it should. The vacuum line from the trans is circled in green, correct? Where is this cable to adjust it? I only have a Chilton's manual for up to 84 mercedes 190E and there is no information on this.
Old Jan 9, 2008 | 04:51 PM
ccb_v2's Avatar
YouTube videos of engine and tach
Engine
Tach
Old Jan 9, 2008 | 06:17 PM
MTI's Avatar
MTI
The Bowden cable has a splined adjustment wheel on it, it's not in the picture you posted.
Old Jan 9, 2008 | 08:23 PM
ccb_v2's Avatar
Similar to the e-brake adjustment behind the rear rotor?
Old Jan 9, 2008 | 08:42 PM
tbenz's Avatar
ML320
did you ck the cap and rotor? also ck coil output, what type of plugs did you use? platinum plugs don`t work well in the older cars,
Old Jan 9, 2008 | 10:32 PM
ccb_v2's Avatar
checked ignition, getting good spark. timing is at 0 TDC. Got non-platinum.
