190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
blowing #2 fuse
Old Jan 17, 2009 | 04:17 PM
dennish's Avatar
1992 MB 190E, 2016 MB C300
blowing #2 fuse
hello, wondering if anyone has input. my 1992 190E 2.6 keeps blowing the #2 fuse. i had the ac compressor replaced last summer and now the compressor won't engage nor will the auxillary fans work (they are not frozen up). everthing else works.
Old Jan 19, 2009 | 11:09 AM
SLOPESTAR's Avatar
99' E320 4MATIC ESTATE / 92' 190E 2.6
i too has a blown fuse/problem with cluster lights. good luck as no one cares about the 190's
Old Jan 19, 2009 | 06:32 PM
Sincity's Avatar
Not true. W201 activity is not lively on mbworld.org. Go to the W201 section in benzworld.org. There is also a dedicated site: 190revolution.net. Good luck!
Old Jan 20, 2009 | 12:20 AM
SLOPESTAR's Avatar
thank you, i will
Old Jan 29, 2009 | 01:45 AM
Runninrebel211's Avatar
1993 190E 2.6
Mine keeps blowing too! I have a 1993 2.6 and every time I turn on my AC in 120 Las Vegas heat the fuse keeps blowing. Something is causing it to draw more amps than normal. I stopped blowing fuses when my fan clutch got fixed. Might wanna check yours. Turn on engine and use an old magazine that is rolled up and see if you can stop the engine fan. WATCH YOUR FINGERS!!!! Those aux fans running for prolong times in hot weather causes it to blow the #2 fuse.
