cranks but wont start
i dont know what to do. my w201 cranks but start. batterys voltage is at 12.63 and im pretty sure its not the atlnator or starter. i was thinking it was the ovp relay but how would you take it off and whats the syptoms. please i havent drove my w201 in a month and ill appreicate anyones help
Go back to the basics: are you getting spark? if not then start there, if you are, then ask and find out if you are getting fuel. If you are getting both, then you need to determine if the timing is close enough to run, or if you have compression.
1 Post
1989 190e
The OVP could be the problem. It is located behind the black plastic shroud behind the battery and is very easy to replace. All you need is a flat blade screwdriver IIRC
When my OVP went bad my car had all kinds of weird problems...
