190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
High idle in park and neutral
Old Mar 8, 2010 | 09:29 PM
richindy's Avatar
1992 190e
Hello everyone,
I am new to this forum, I hope someone can help.
I have a 1992 190 E 2.3, Just got done putting the right head light harness back in, and put new fluid in also. Once the car warmed up nice, the car went to a high idle in park and neutral position. can anyone please tell me what it can be? I have been working on this car for almost three years and I am almost got this car running smooth.
Thanks.
Old Mar 11, 2010 | 05:14 AM
zedzilla's Avatar
300ce
Consumerguide reports the following:
Engine misfire: The idle speed-control motor may stick causing a high idle or surging idle. (1990-93)
Check this link under the "trouble spots" section
http://consumerguideauto.howstuffwor...benz-190-6.htm
Dont know anymore about this to elaborate further. Maybe check that motor for fault first. Hope this helps.
Old Mar 14, 2010 | 08:31 AM
richindy's Avatar
1992 190e
Thank you zedzilla for you your info, sorry it took so long to reply to say thank you. I did check for faults there was none. I did notice the plunger on the throttle area was sticking, so I cleaned and lubed the throttle linkages and plunger. I drove the car for an hour and never got the high idle in park or in neutral. If it dose happen agian I will be looking at the idle speed control motor as specified on your quick link you had sent me. Thanks again, Im a happy person with a 190 E.
