Rough start up
Today car was parked in the driveway (which is an incline) with the car facing uphill it cranked for 5 seconds. So put it in neutral and rolled it into the alley which is pretty flat and it started after a few seconds. It seems to start and run like crap when I park it on a level surface. I started the car while it was warm on a level surface it first started and died then on the second start up it rev'd up to 3k RPMs and stayed there so I shut it off again. The third start up was normal, what the heck!
I have no idea what would cause this weird starting issue, possibly a problem with the throttle body??
Everything helps
-Brian
It has trouble starting, chokes and dies, it will start with a tap of the gas pedal. once its running its smooth.
-Brian
