front brakes sieze up 1986 190e 2.3/8
First had the master changed...clutch not working. 1 month later front brakes started siezing up. Could barely move car off the street. After cooling 1/2 hour drove ok to get it home but wheels hot again Then had front hoses changed. Same problem. Go a mile or 2 and the front brakes drag. Wheels hot enough to burn you. Now I'm told I need a power brake booster. Rear brakes always worked fine. Could a booster lock up only the front wheels ? Please, any advice would be appreciated. I just got this car from a family member to help me out....I'm on Social Security and can't really afford expensive parts just to try. Car has 88,000 mi. Sat in garage for a year. Thanks, Dave
Oh damn, STOP Driving the rcar you will warp the rotors.
Well, you can try to see if the calipers are binding due to corrosion from broken/cracked seals at the pistions. It may need to be rebuilt with new seals. Brake fluid is very corrosive.
Are you absolutely certain proper DOT brake fluid was used?
Wow, this car is not cheap to replace parts but if you access to Pick a Part, there are many 190e's that you can salvage the booster from if the brake line has not been open to the elements.
If you are not a DIYer, it will cost you.
