190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
RPMs at 60 MPH?
Old Apr 29, 2015 | 08:03 PM
autobon7's Avatar
1990 190e 2.6
RPMs at 60 MPH?
The trans in my recently acquired 1990 2.6 is shifting a bit wonky mainly when cold. The shift points are obviously not met. Like when leaving the driveway the rpms run up pretty high (3000 rpms give or take) before engaging the next gear. Often times if I back off the throttle a bit it will then shift to the next gear. When up to operating temp all seems to be well. Curious though.....at 60mph I am seeing 3000 rpm which seems high. Have the feeling I may have some expensive work coming up. Any thoughts are certainly appreciated.
