190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
New to me 190E 2.6
Old 01-25-2017, 08:25 PM
Raidriar's Avatar
'89 190E, '11 C300
New to me 190E 2.6
I just acquired a new to me 1989 190E 2.6. It looks to be in great shape, cosmetically and mechanically. However, it has a nasty issue where it sometimes stalls and dies when slowing down or idles rough and dies. PO has tested the injectors, found to be fine, replaced fuel distributor, fuel accumulator, fuel pump relay, cleaned the air metering device, replaced EHA valve, and cold start valve. he also put in a new voltage regulator but it was not the bosch brand.
Where do we go from here? Great car on the highway, just rough idle and dies intermittently, more so at cold start.
I neglected to ask if he had done sparks, distributor, rotor recently. Is this more an ignition problem or a vacuum problem?
Old 03-06-2017, 10:31 AM
Max Thrust's Avatar
G's + 190
Did you change the fuel filter? If it's clogged/dirty, then the fuel pump will be working extra hard to feed fuel to the engine. When you come off the gas pedal, there may not be sufficient pressure at low RPM to draw fuel through a dirty filter.
An easy item to address, but important. Cheap too. Try it.
Obviously all elements in the engine bay are important - especially on older cars, they don't have the technology to compensate/adjust too much. Cap/rotor/wires/spark plugs are all important and cheap to do.
Old 04-19-2017, 01:45 AM
Sport line's Avatar
1993 190e 2.6 Sportline
Voltage regulator in the back of the alternator. Change it if you not sure when it was replaced last. Replace the ovp at the same time.
Old 08-09-2017, 07:20 AM
BenzCube's Avatar
91 190e 2.6
Distributor Cap
Have you tried changing the distributor cap. I had similar issues and that is what fixed it for me.
Old 10-16-2017, 11:14 AM
AdriSport4's Avatar
Mercedes
______
Old 10-18-2017, 03:50 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
The first thing I do when I buy a 190 is replace all of the vacuum lines. All of them. You will be surprised what under 10 bucks and an hour or so will do for the car.
Quick Reply: New to me 190E 2.6
