Engine mount
Ive discovered that the steering judder is caused by the steering rod from the steering box touching the exhaust downpipe when on or near full lock. Question - is it possible to shift the downpipe slightly? and is it possible that th eengine has moved slightly - an engine mount problem? also what should the minimum clearance be between the downpipe and the steering rod?
Does anyone know?
