190e 2.6 having a hard time starting. need help!
ok guys i need your help!
my 89 190e 2.6 is have trouble starting. the 1st time i start the ignition, it sounds like its gonna fire, but when i let go of the key, it dies. and i can only start it on the second try. whats going on here? is there something that needs to be replaces?
See sig.
I'd try the following (assuming recent tune-up, and everything's in pretty good shape):
1. Change the OVP Relay
2. Change your fuel accumulator and/or fuel filter
3. Change your fuel pressure regulator.
Cold Start Valve or the Engine Temp Sensor that controls the Cold Start Valve and CIS-E system. Mine did the same thing, I cleaned the cold start valve and replaced a bad Engine Temp Sensor and all was good. Check out 190revolution.net forums, very good for this kind of info.
2.6 Hard Starting
I have this start problem where after it sits for about 15 to 20 minutes, I go to start the 2.6 and I have to crank the starter for almost 10 to 15 seconds before it starts to slowly chug up to speed. Then she runs great after that. I checked the 10 amp fuse behind the battery. It's fine. I changed the spark plugs and air filter. Then ran some Techron through the fuel system. I just got the car. It has 35,000 miles on it. The engine compartment is spotless. This is the only issue I have with the car. Any help here would be great.
is 2.3 the same
Rod
'84 190E
'96 S320
Yes they are the same as far as that goes. You may want to get a hold of the W201 Service CD, it has a lot of good info on it and how to fix just about everything. You can finds them on E-Bay. Some people at 190Rev have them as well if you ask.
Sorry to show my ignorance but what is 190REV ? And thanks for the info about the Cold start Valve & Eng Temp Sensor.
Rod
'84 190E
'96 S320
Rod
'84 190E
'96 S320
190Revolution.net is a site dedicated to everything 190 related. Right up to the EVO I and EVO II's that were only sold in Europe. Aska question there and within an hour or so you have a lot of info. That is where I got any knowledge I have on the W201 class and have fixed a ton of issues without needing to visit a shop.
Sounds cool, do you know if they have any such site for other Mercedes ? Like maybe my S320 !!! I did hear the CD is about to be released, that will help ( for a price ).
Well I hope someday to be able to pass on some knowledge as good as you guys have provided.
Rod
Rod
