190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
water pump drain/leak?
Old May 23, 2004 | 04:20 PM
nutkick's Avatar
what is the drain hose coming off the water pump for, why would coolant constantly drain out of this hose, and what would fix this problem?
Old May 23, 2004 | 09:10 PM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
Drain hose at the water pump?
In this pressurized system, the only drain hose is at the neck of the plastic expansion tank, not on the pump. The pump connections should be to the thermostat, the bypass line from the thermostat housing to water pump, lower hose to the radiator and to the return line from heater pump.
Old May 31, 2004 | 01:10 PM
E-Klasse's Avatar
W205 C300
Are you talking about the weep hole? If there is antifreeze coming out of there then your shaft seal is bad and the water pump needs to be replaced.
