r16 resistor again...
well after much debate i've finally decided to pull it out. upon doing so my car transitioned faster at higher speeds. so for example if i was cruising at 40 and then wanted to go up to 60, normally there would be a delay before the engine kicked in
with the resistor out there was literally no delay and it went right into it. so far no pinging has occured and it seems to be fine. has anyone else pulled this out ? i know there has been much controversy over this, just wondering what others have done, and/or have decided to do it.
1994 E320
Now that you have done this, the EZL will interpret the open circuit as a fault condition and retard the ignition timing to the max. Now you will suffer poor fuel economy and loss of power. However, I can not imagine how you get more power by doing this.
If you are looking for quick off-the-line response, a Mercedes is the wrong way to go.
No resistor = no retard
2.4Kohm resistor = 2 degree retard
1.3Kohm resistor = 4 degree retard
750 ohm resistor = 6 degree retard
470 ohm resistor = 8 degree retard
220 ohm resistor = 10 degree retard
0 ohm resistor = 12 degree retard
The person who created that table had the 750 Ohm resistor in his 2.6.
By what I just posted you should not. These engines do not have knock sensors to retard timing in the event of a knock. It has yet to be seen though if by removing the resitor it actually does anything to give more power. No dyno's to prove either way. Your best bet is to look at the resistor list and pick the 2 degree retard one and order it from your dealer.
Power comes from compression not higher octane. A good tune up would do more to restore power. Why convert a car that runs on the lowest priced fuel to burn the highest price fuel when gas prices are at an all time high. Unless you up the compression ratio of the engine, it is a waist of money.
Hence why I said no one has proven that there was a gain of any kind. I guess you read past that part. The only thing it will do is maybe give you better acceleration, but as stated why do it with todays gas prices. It will only give you a better combustion cycle, if it even gives you that. Since the CIS system along with the vacum advance on the timing normally will correct for any changes. Unless you were to actually buy the correct resistor for the Octane fuel that is being used. Most cases show a decrease in fuel economy and that is about it.
i've always used premium gas (93+), on my 190e it says only to use premium, i pay the high gas prices and in the 6 years i've had this car i have used premium, so if i get better acceleration using the same gas that i've always used doesn't it make sense or am i actually ruining the engine ? i'm not trying to fight i just want to know, if i'm getting a better acceleration using this gas should i keep it out ?
The stock 2.6 one is the 750 Ohm resistor. So you could have less retard by upping the 1.3 or 2.4 KOhm ones. Most likely you will gain a better throttle response and maybe get your spark at the right time and thus having combustion in the chamber at the right time. Better more efficient combustion will actually produce the best power outpur for the motor. Since you will not be combusting just before or during exhaust valve opening.
Oh and E-Klasse, it is easy to gain more power without changing the compression on an engine. It is done all the time and is called Forced Induction. Not changing the compression ratio at all but forcing more air and fuel into the chamber for more combustion and more power. Combustion is what produces the power not compression ratio or compression. Yes the proper compression ratio is needed and is dificult to change, but put more air in the chamber and more fuel and perfect timing and you yield the best Hp results. Like adding a cold air intake will add a few ponies, not because I changed the engine, but because I am feeding cooler air into the chamber and most likely a little more air due to better flow. Thus more power when I add a hair more fuel. The colder more dense the air the better the combustion and the more power output.
Originally posted by E-Klasse
What year is your 190E? My owners manual for my 86 sais to use 87 octane. I did hear that some dealerships were just putting stickers on the gas caps or on the fuel doors that said to use premium gas only in an attemp to sell them off as better performance cars. People still think that premium gas is better gas so better cars must have to use premium gas. That is a misconception.
1993 2.6 and it says premium only in the dash in the instrument cluster, i can show you a picture, i've always put in premium, so should i keep the resistor out if i'm noticing a difference ?
1993 190E Silver
I am not an owner but I was doing research on what sort of modifications and problems people experience with the 190E. I tried to go over to 190revolution.net and noticed that they have exceeded the bandwidth limit already for the month, does anybody communicate via email with those people so that we might find out when their site will be back online? There doesn't seem to be too much information here about adding turbos onto the 190E when I use the search. I hope to join the group soon owning, but for now I am just researching. Thanks!
That is the first time in a year I have seen them exceed the limit. I am not sure what is going on over there. But I can't get my damn 190 fix so I am going nutso. Hopefully it is back shortly. There is a nice thread over there of Turbo adding, not to mention swapping out motors to an M104, and threads on upgrading to EFI as well.
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
190Revolution.net is experiencing a Denial of Service (DoS) attack. Apparently, someone has a grudge against the forum and is flooding the server with TCP requests that keep other users out. The problem is being addressed.
E-Klasse, the pre-1987 190E's had a 8:1 compression ratio and used regular 87 octane fuel. IN 1987 the Compression ratio of the 2.3 was raised to 9:1. We have 120Hp and the 1987+ had 130, they also gained 10 ft/lbs as well.
Higher compression will cause pre-ignition (example, Deisel engines use high compression for ignition)
Higher Octane fuel ignites slower so that it can be compressed more before it will pre-ignite. You want the spark plug to ignite the fuel and not the compression.
The extra HP is not caused by the octane rating. But the higher octane is required because of the higher compression in the cylinders.
Once again, this subject is not about turbos or a superchargers. I am not making any sugestions about how to add HP to an engine.
That is my point, 8:1 compression = 120hp and 9:1 = 130hp.
Also something to note about the pre-1987 and 1987-on is that not only was the compression ratio changed, but the fuel system updated to KE-III instead of KE-II that is in our 190's. I am not sure how much else changed as well to get the power up, but I assume more fuel and air as well as the compression ratio change probably were all that was done. With some sensors changed as well.
But alas the question on the R16 resistor has been answered, and changing the timing could gain you a few ponies but also cause you to need higher grade gas since the spark will be firing later. And also to point out that power is not achieved by compression alone, but also by how good the fuel/air mixture burns as well as how much fuel/air you can squeeze in there to explode.
It was your kick not mine. Like I said, it is not worth it...
Maybe I can just pick up a 16V motor or an M103 motor cheap and swap it out. Who can tell, I am just getting the car to finally run good and get better mileage, but still have managed to only spend about 200-300 bucks on parts and did all the labor myself, which is the same as I would do to EFI or Turbo it.
190e 2.3-16valve
question
whats up guys does anyone know where i can find those rear winshield spolers.....please get back to me as soon as possible i wnna put one on my 85 190 16v thanks
