190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
New Project: 190e EVO II replica with M113 5.4 AMG
Old Dec 1, 2022 | 04:41 PM
  #76
mbz2oh1's Avatar
040 E320 S124, Smoke Silvr W201 2.6
Love the updates, I'm a fan.
Old Dec 16, 2022 | 10:57 AM
  #77
Hooblah's Avatar
Merc
Amazing work. I've got a few questions if you wouldn't mind answering?
1. I see you've used a w211 rack. How did you set it up to avoid bump steer and for correct ackermann?
2. Have you modified the steering arms? If so, how?
3. Have you installed a bearing to support the steering column near the firewall?
4. Have you got the engine sitting totally level, or is it angled down a couple of degrees towards the rear end?
5. Is the engine situated optimally for balance, or do you think it needs to go back further?
Old Dec 16, 2022 | 02:33 PM
  #78
olszowa12's Avatar
'08 C63 Estate
We have not done an alignment yet. The steering arms are a frankenstein mix of W210 inner arms and 190e outer arms.
The 190e outer arms were cut in half, shortened, drilled and threaded from M12 to M14. The w210 inner arms were shortened and threaded so the 190e outer arms could screw onto them.
Maybe the pics will tell you more than my words But unfortunately I did not take any pics of the final outcome - the steering arms are much shorter now, than on the pics you can see below.
I haven't installed a bearing in the firewall for the steering column. We'll see if it's necessary when I finally get to drive the car.
The engine is level and as far back as possible - in fact it's so far back, that I cannot fit the stock air intake that goes into throttle body.
I had use a silicone 90* hose and cut the stock intake. In the future I will probably cut into the firewall to make room for the OEM air intake.
My time in the garage is limited so the progress is slow but the wing is now mounted. Fits great, just the trunk is a bit heavy now - gotta watch your fingers
The rear bumper, sideskirt and door trims were mounted too. I also checked how my NOS Momo Corse exhaust tip will look - it's a perfect fit for this bumper.
I like it much more than the oval EVO2 exhaust tip.
I also replaced the old ugly coolant reservoir for a new. Much better.
The stock ECU was sent to be flashed and coded - I am hoping to have it back before the end of the year.
Old Dec 16, 2022 | 05:22 PM
  #79
Hooblah's Avatar
Merc
Nice.
You probably don't want to hear this but it looks like you're going to suffer heavily from bump steer because your rack is too wide and in the wrong position. This is what makes a rack conversion so difficult on this car.
Old Dec 17, 2022 | 06:16 AM
  #80
olszowa12's Avatar
'08 C63 Estate
Nice.
I am aware the rack is too wide. Why do you say it's in the wrong position?Take into account that the car will be lowered another 6-8cm in the front.
It's all trial and error. I will see how it works, as I haven't seen any other steering rack conversion done on an 190e - just the W210.
The old rack&pinion was a no-go for this project.
Old Jan 17, 2023 | 04:08 AM
  #81
olszowa12's Avatar
'08 C63 Estate
The 190 got a reflashed ML55 ECU so it went finally for some wiring work. Can't wait to hear it run after such a long time.
Got some new wheels to build up my motivation. Always liked these and a deal came up I couldn't pass up.
Rotiform LAS-R 18" 8,5+9,5 ET30
Old Jan 27, 2023 | 10:13 AM
  #82
olszowa12's Avatar
'08 C63 Estate
Old Feb 2, 2023 | 11:57 AM
  #83
Hooblah's Avatar
Merc
How much did you have to cut here?
Old Feb 3, 2023 | 07:55 PM
  #84
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
cool build for sure. one of my customers is doing something similar except he shoved in a m113k and did a full interior swap from a w211 e55.
believe he is working on the wide body kit right now
Old Feb 4, 2023 | 02:34 AM
  #85
olszowa12's Avatar
'08 C63 Estate
No cutting, just a few bangs on the secondary firewall to move it away from the coilpack.
To be honest, looking at the engine bay now, a lof of the issues were caused by the fact that I wanted the engine to sit as close to the firewall as possible.
If I moved it a little to the front it would not be an issue. But we have plenty of space to service the engine now.
Thnaks. M113k is sick but an overkill for me - N/A M113 power is enough for me. As for the interior, I prefer the 190e interior.
Old Dec 26, 2023 | 04:50 PM
  #86
olszowa12's Avatar
'08 C63 Estate
Haven't posted for a long time because none of the previous photos were loading so I thought the forum was dead.
The car is now painted and fitted with the evo2 kit. Got a new stainless steel valve-controlled exhaust, a new Recaro Spectrum interior and Airlift 3P suspension.
Got a new discreet license plate as well. We still have a lot to do, but it looks alright.
The Rotiform wheels are just temporary. Got a new set of wheels ordered - no shortcuts this time.
BTW the W211 steering has to go - I will try an e36 steering rack as I heard it's narrower and works better.
Old Jan 3, 2024 | 09:01 AM
  #87
ilax028's Avatar
Nothing Yet
Thank you for posting. This is a dream build for most of us.
Old Jan 3, 2024 | 09:06 AM
  #88
dan190's Avatar
89 190E + 99 C240 + 00 CL500
+1 WOW just WOW man !
btw love the "snowplow" mod ))
Old Mar 6, 2024 | 06:55 AM
  #89
Ferreiraclovis's Avatar
e55 amg
Congratulations on the project, we put on the 190e from 1991, an m113 from e55 amg from 2000, and we are having some problems, can you help me?
My car is a 2000 E55 amg, the fuel pressure is 58 psi, is this correct? I saw comments of 55 - 60 psi and others of 70 - 77 psi, which is correct?
Old Apr 20, 2024 | 02:59 AM
  #90
Pirublues's Avatar
'67 250se - '80 450sel 6.9 - '93 190e Sportline
Have you done the e36 rack yet?
Old Apr 21, 2024 | 02:36 PM
  #91
olszowa12's Avatar
'08 C63 Estate
No, I am trying to keep the W210 rack for now. It's not the perfect solution but it will do for now.
The e36 rack won't work with a V8 swap probably - it's been only done in a R6 engine swap.
I've seen people were able to retain the original steering box in a V8 190.
One MB tech used a W124 E500 steering box - you can check out his youtube vid:
Old May 5, 2024 | 03:21 AM
  #92
sathvik989's Avatar
GLA 35 AMG
Hi, I am looking to buy a 190D and do the same swap, in this Video when he said SL600 front knuckles/spindles did ne mean R129 or R230 SL?
Old Oct 12, 2024 | 05:33 PM
  #93
Joes_Benz's Avatar
Motor Mounts?
How did you do motor mount brackets, I'm working on putting a 5.0 m113 in my w201 and need a blueprint or CAD drawing of the brackets if you still have them. This is also my first post ever, So I don't know what I'm doing thanks.
Old Oct 15, 2024 | 06:38 AM
  #94
olszowa12's Avatar
'08 C63 Estate
R129
We just made them as we went along. Trial na error. It depends how far back you want the engine to sit - mine is at a point where I had to cut the removable firewall because it was hitting the intake pipe, but I am still able to service the engine from every side. We just did the valve seals without removing the heads - finally no more burning oil for me. Some people install the engine more towards the front to avoid body cuts. Recently I've talked to a guy who installed an M113 in a C124 so far back he can't even take off the valve covers... It's all up to you.
Can anyone tell me why I cant see the pics uploaded to this thread?
I tried viewing this hread on multiple devices and different browsers. I cannot upload any new pics as well.
Old Oct 17, 2024 | 04:22 PM
  #95
olszowa12's Avatar
'08 C63 Estate
it seems I can see and upload images again. (Thx Jeremy)
the 190 looks different now. Got some new wheels - custom BBS LM with double step lips - and a chrome front grille to match. Can’t imagine this car looking any better so this is probably the final version.
In the last few months I was able to attend a few car events, did some roadtrips and all I can say is that this car is a highway missile. Very comfortable, spacious, economical and fast. Before my latest 2000km trip to the Tatra mountains I was able to replace all valve seals without removing the heads. So the engine is fully serviceable as it sits right now - super happy with that.
there are still some steering angle and jerky transmission issues but we’ll get there. I’m in no hurry and this is my 1 of 4 project cars so I’ll take my time.
i’ll try to upload more pics from the last months.
I upload on a weekly basis to my instagram @revolte_
Old Oct 17, 2024 | 05:22 PM
  #96
Pirublues's Avatar
I'm going to message you on Instagram
Old Oct 21, 2024 | 08:24 AM
  #97
olszowa12's Avatar
'08 C63 Estate
i dont know whats wrong with the forum by uploading pics takes forever
Old Jan 16, 2026 | 08:27 AM
  #98
KAPRIS's Avatar
Jaguar x308 (M113)
Very nice build. I have noticed you are based in Poland, maybe you could share contacts of a person who flashed and coded stock m113 ecu?
And would you do it again or use some standalone ecu?
Old Jan 20, 2026 | 03:13 AM
  #99
olszowa12's Avatar
'08 C63 Estate
Poweride - they coded my ECU.
My current setup works very well. Next time I would go with a standalone ECU though - I would gladly remove some of the sensors in the engine bay to clean it up.
If you're on a budget, flashing the stock ECU is definitely they way to go.
Old Jan 20, 2026 | 04:09 AM
  #100
smgak's Avatar
C230K
Congratulations! Your hard work has brought this beautiful car to life. I hope you’re enjoying it!
