Engine Swap for 190, M111 vs M102
Initially, I wanted to put an M103 or an M104 in my 190 but seeing that i'm working with a inline-4 2.0L base model, drastic changes might be needed to fit an inline-6 (please correct me if I'm wrong) and i'm also worried putting a 2.8L/3.0L in my 190 would make it nose heavy.
So I came down to two options:
1. Buy a W124 230E and rip out the 2.3L M102, put it in my 190 and turbocharging it.
or
2. Buy a W210 E230 and rip out the 2.3L M111, put it in my 190 and turbocharging it.
the reason I'm going with the Na M111 over the Kompressor model is because i've read and heard that superchargers are space heaters (again, please correct me if i'm wrong). The 190 is one of my daily drivers and traffic here in Jakarta is just abysmal, don't wanna risk the car overheating. So which option do you think would yield the best result?
All I know is that changing from a carbureted engine to a CIS fuel injection will not add very many HP's for the same displacement.
No matter what this is a big job, and if you are going to tackle it you would want the most out of this project. An M102 2.3L or even an M103 2.6L is probably not worth the effort.
M104 HFM (E320) is where it would start making sense at least mechanically it should be a bolt on. Electrically, a lot of work. Same with the M111, but the adder there is more mechanical work on top of the electrical fuel management system.
You are probably better off finding a cheap car with a good body and a good M103-2..6 liter engine but trashed interior and start transplanting all but the engine and the chassis to the newly acquired car. I think that is a lot less work and less messy. A manual tran M103-2.6 has satisfactory power but not good enough for what you will be attempting.
Would going for a 3.2L inline 6 require me to do major modifications to the bay or firewall? I've read somewhere that with M104's you need a 190E 2.6 as a base due to the different location of the steering box compared to M102 cars. Moreover, Would going with a big engine kinda throw the car off balance?
As for the acquisition of a new car, It's highly unlikely for me right now as I just can't get behind the economics of it. 190Es are very rare here in Indonesia, and the ones that are on the market are in too good of a condition to take apart. Kinda hard justifying a $20k (minimum) purchase when I know an engine swap is gonna cost way less here (low labor cost).
How many miles on the 2.0L engine? Is it worthy of all this custom work? I still believe a 3.0L from a 300E might be the most straight path to your success. Been done many times. You would go from 100+HP or so to 170+HP. That is a big jump.
At least you do not have to worry about the mechanicals other than changing out the radiator area and crossbar.
