1986 190E 2.3L SunRoof
1986 190E 2.3
Hi. When I purchased the car, the sunroof worked. Now, however, it does not work at all. I checked the fuses and they are fine. Any ideas? Thank You.
1986 190E 2.3
I found the motor you told me about. Interesting, when I click the sunroof button, the engine makes a quick "click" noise. Do you know what this means?
1 Post
'85 190E 2.3-16 '99 C280 '11 GLK350
It could be the motor relay switching, but you should be able to hear the sunroof motor turning. I would start to suspect that the motor isn't getting power or is dead.
1986 190E 2.3
Do you think that the motor is possibly "stuck"? I have had similar things just be stuck and need to be manually given a push start to get things back on track. Is there someway I could manually open the roof to see if that helps?
1 Post
The sunroof can be manually opened by using the socket that comes with the tool kit to drive the external nut on the sunroof motor. Otherwise, just get a deep socket of the proper size to turn the nut.
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
Just becareful not to strip the plastic handle on the motor (The tool is metal). I have the same problem on a 190D and the dealer quoted me about 300$ to fix relay and I think replace the motor. (it would open but not close at times). I figured it wasnt worth it so I closed the sunroof and just left it alone.
