190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
1986 190E 2.3L Tachometer Broken
Old Oct 29, 2004 | 10:45 PM
codyman's Avatar
1986 190E 2.3
Hi. Although my car is automatic and a tach really isn't important, I was wondering if someone knows what I can do to fix it. The needle is constantly at "0". Is this a cable or electronic driven tachometer? What should I check which might be the problem? Thank You.
Old Oct 30, 2004 | 02:57 AM
MTI's Avatar
MTI
'85 190E 2.3-16 '99 C280 '11 GLK350
The tach is electrical, so either the fuse, physical wiring connector or the sensor is at fault. The only cable driven gauge is the speedo. Early, pre-85 models have a "live" oil line for the pressure, but after that they were electrical.
Old Oct 31, 2004 | 03:31 PM
codyman's Avatar
1986 190E 2.3
I checked the fuse and it is fine. In terms of the sensor and wire, where are they located? Thanks
Old Nov 1, 2004 | 03:59 PM
MTI's Avatar
MTI
From the rear of the instrument cluster, the tach signal comes through the fuse box, then to the fender mounted ignition control unit, then from the distibutor coil.
