Where to get 7 pin OVP Relay?
Due to a few issues I've determined I should probably eliminate the OVP relay as a potential cause, and the symptoms of the car agrees.
The part number for mine is 201 540 32 45 but all the ones I can find new are 9 pin part 201 540 3745.
I did end up buying a 9 pin thinking there might be blank spaces for the 2 pins that would simply go unused, but it doesn't fit at all. What's the play here, is there a way to get a new replacement at a reasonable price? These 9 pins seem to be priced reasonably, but I can only seem to find expensive second hand relays that match mine, and I don't see the point in replacing it with a part that is just as old as my car.
I have a 1992 2.0 190E.
Appreciate any assistance.
I've attached images, sorry for the size, I don't seem to be able to modify it here.
I might first risk a used one due to the price difference. I have found an online store that seems to sell a new one for £100 which is a hell of a lot.
You can probably match the circuit drawing on both parts to just connect the common pins. There must be a writeup on this somewhere on the internet.
Will require some soldering. If you attempt such a thing you must disconnect the components (ECU, EZL etc that the OVP is connected to. Otherwise you may damage those components.
I'll try to buy a replacement, but this might be a suitable backup solution.
Thanks for the reply.
