190E (W201) 1982-1993: 190E 2.3, 190E 2.6, 190E 2.3-16, 190E 2.5-16, 190 D 2.2, 190 D 2.5, 190 D 2.5 TURBO, 190E 2.5-16 Evolution I, 190E 2.5-16 Evolution II
Front brake questions?
Old Jun 24, 2025 | 10:37 AM
Dave Kost's Avatar
1993 190E Sportline; 1992 190E 2.3
I just replaced the front brake pads and rotors on my 1993 2.6 Sportline with OEM Mercedes parts that I purchased from a dealer. The wear was pretty much even on both sides comparing both rotors and pads, so I didn't replace the brake line hoses or bleed the system. I had to push back the piston all the way to get the new pads to fit , and they just barely fit without rubbing. The PO mechanic used blue loctite on the caliper carrier to hub bolts and they were crazy hard to get out.
Two questions-
What is the torque on the caliper carrier bolts to hub and slide pin bolts? ( I found conflicting info)
Does anybody bed in the brakes on your 190e's?
Thanks,
Old Jun 24, 2025 | 01:33 PM
190Efan's Avatar
1991 190E 2.3
The MB Classic Center can tell you what the correct torque is for the caliper carrier bolts as I'm not sure what it is.
Old Jun 24, 2025 | 11:22 PM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
Hi Dave, previous owner must have overused the blue loctite. Only the 1/4 inch tip needs it.
My Hanes manual says front caliper mounting brackets are 85 foot-lbs. Super tight. Haynes is usually correct.
I remember it being tight. I have guide pin bolts at 22 foot-lbs in Haynes.
