A45, A35 AMG (W176, W177) 2013 to present. Two generations
change rear brake pads
Old Dec 24, 2017 | 01:10 AM
Bennoo's Avatar
cla amg 45
Hi All
Can some one tell me how to deactivate the read brake electronic park on my CLA45 so I can change by brake pads. I thought there was a setting that releases the callipers however cant find it anywhere.
Thanks and Merry xmas
Ben
Old Feb 23, 2018 | 05:48 AM
Greta's Avatar
A45 AMG 2014
Hi Ben
I had the same problem and somehow stumbled across a video on YouTube showing how to release the calipers. I have A45 but should be the same as yours i think. You should do the following procedure but do it quick. Key in ignition turn to position 1 press and hold phone answer button then press and hold OK in about 5 seconds the menu will appear scroll down to PAD REPLACEMENT then OK and OK again you should hear the calipers retracting. Then it's pretty same as changing any brakes. Hope this helps
