A45, A35 AMG (W176, W177) 2013 to present. Two generations
Turn signal / steering stalk click noise
Old Sep 1, 2022 | 08:42 AM
Slickster514's Avatar
2022 A35 AMG
This is probably normal but I would still like to confirm...........
After signaling for a turn (either R or L) I begin to turn the steering wheel in the appropriate direction, when I get to about 25 degrees or so I can hear a small click. Past this point, returning the steering to 0 degree position would cancel the turn signal. Same exact behavior on the other side. Is it normal to actually hear the click sound??
Old Nov 17, 2024 | 04:41 PM
alexis124's Avatar
Hello,
Did you find the answer?
Mine does that too...
Old Nov 21, 2024 | 04:59 PM
alexis124's Avatar
Hello,
Any update?
It's needed to repla the entire indicator body? Or is an easy fix?
Old Jan 4, 2025 | 05:52 PM
MBAUNI2's Avatar
AUDI
It is completely normal to hear this click, and it indicates that the mechanism is working as it should. In fact, it is a sign that the turn signal system is designed to help you automatically deactivate the turn signal after a turn, and this ensures a safer and smoother ride.
Old Jan 4, 2025 | 07:59 PM
W205C43PFL's Avatar
Wait... I thought all cars does that, not just MB.
Old Jan 14, 2025 | 02:58 AM
razacs's Avatar
Honda
It sounds like you're experiencing the common 'clicking noise' that often comes from the turn signal stalk in the A45/A35 models. It's likely due to the mechanism inside the stalk that's responsible for the turn signal activation. If it's bothering you, I’d suggest getting it checked out by a certified Mercedes technician, as it might be something that can be lubricated or adjusted to reduce the noise. But overall, it's a known characteristic of the design in many Mercedes-Benz vehicles, not necessarily a fault.
