Ipod hookup from Mecedes ?? What Happened .
Old 06-09-2005, 03:28 PM
medriver99's Avatar
Did anybody get the unit for the Ipod hookup from Mercedes yet??
Mike
Old 06-09-2005, 08:16 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Yes, people have, you may want to use the "search" function here at mbworld for further information.
-s-
Old 06-09-2005, 11:57 PM
Wolfgang's Avatar
MBs
Mike
Mike, here are some Ipod upgrade kit part numbers which are available from Mercedes-Benz in Germany. Have not figured out the MBUSA part numbers yet.
C-class (starting 4/2004), CLK (starting 7/2004): B6 782 42 13
This one costs 157 Euro and works with steering wheel controls and display in the instrument cluster.
New M-Class: B6 782 42 16
E-class and CLS (only with COMAND): B6 782 42 02
new SLK (only with COMAND): B6 782 42 09
Old 06-10-2005, 05:35 PM
Oslo's Avatar
From the E-class:
Old 06-10-2005, 09:11 PM
scorchie's Avatar
Current part number for US-spec M-class is B6 782 42 01. Likely differs from Euro M-class because of different radio choices; the C- and CLK-classes will probably have the same differences.
-s-
Old 06-11-2005, 10:45 AM
Wolfgang's Avatar
MBs
-s-
That's also the part number for the OEM Euro W164 M-class. It's also listed on the website in Germany.
The number I posted is for the retrofit kit for M-Classes. That's B6 782 42 16. (Different for C and CLK).
Old 06-11-2005, 11:01 AM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Ipod/MP3
Suggestions for stock radio (1998 C43)....I have a creative labs 60Gig MP3 player I would like to use. That radio transmitter deal is crap!
Old 06-11-2005, 01:05 PM
scorchie's Avatar
What's the difference between retrofit kit and the non-retrofit kit? The 42 01 part sure looks like a retrofit kit (comes with tape, screws, adapter wiring harnesses).
So from what you posted, it seems the MBUSA part numbers are the same.
-s-
Old 06-11-2005, 01:36 PM
Wolfgang's Avatar
MBs
-s-
yes. Looks like the 42 16 is the current part number, and both are for the same M-Class retrofit kit.
BTW, the W211 kit connects directly to the AUX input on the COMAND and not in the glove compartment. That's why the COMAND is required, for the AUX input only.
Old 06-11-2005, 02:23 PM
medriver99's Avatar
I have a W203 C230SS with an AUX input in the glove box will any of these work for me.
Thanks Wolfgang
Mike
Old 06-11-2005, 03:45 PM
Wolfgang's Avatar
MBs
Thanks Wolfgang
Mike
Mike, yes, this kit should work for you:
Or, the new MP3 CD-changer for MOST, part 211 something. Then the titles would show in your COMAND.
Old 06-13-2005, 03:18 PM
99ML320's Avatar
ML320 (Dead), ML55 (Sold), E500 (Sold), Cayenne S (Sold), E550 (Sold), Cayenne TurboS, GL550, GLC300
Retrofit for M
I don't get it, are you saying that the new iPod kit can be spliced into the MCS Harness? I tried "iPod Retrofit" as a search and the other two combos and still the same threads that talk about the release of the technology. Wolf if you can help me out with a thread number or link I would greatly appreciate it.
Old 06-13-2005, 04:03 PM
scorchie's Avatar
The M-class kit also connects directly to the aux input on the COMAND or MCS2, as well... it doesn't go to the auxiliary input jack NOR to the auxiliary input separation point! The instructions indicate that the aux cable should be "discarded". Yeah, right!
-s-
Old 06-13-2005, 04:28 PM
Wolfgang's Avatar
MBs
The M-class retrofit kit discussed above is for the W164 (06+ M-class) only.
For a 99 try e.g. a tape adapter like the Monster iCarPlay, or the new SmartDeck, or the Bipes Automotive direct connect to the Bose audio lines.
http://www.whnet.com/4x4/radios.html
Old 06-13-2005, 04:40 PM
Wolfgang's Avatar
MBs
-s-
Presumably that's for the 42 01? The 42 16 is for the W164 with Audio 20 CD, Audio 50 APS and COMAND/APS (NTG-2). This might explain the different numbers.
Old 06-14-2005, 03:23 AM
gmdebruyn's Avatar
2005 E55, 2010 ML350
a bulletin just went across to all dealers this week stating the ipod kit would be available (at least for the 2005 E) August 1st. only a few more days...
Old 07-05-2005, 03:42 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Thanks Wolfgang for the part numbers.
Just received the B6 782 42 13 kit from Germany for my C55.($300 CAD landed)
Should have it in by the end of the week
Will keep you posted
Old 07-05-2005, 11:54 PM
DCdriver's Avatar
New ML350 with iPod integration kit
1. having the ipod hard wired in is a great feature - can't believe more mfgrs/models don't have this yet.
2. ability to integrate ipod into the new 06 ML was a real plus when we compared new suvs
3. having said that, I am a bit disappointed in the ineroperability of the ipod kit. If I just plugged a wire from the ipod to the jack, it's my understanding that I could have then controlled the song/playlist from the ipod itself and had it come through the stereo AUX. With the integration kit, the ipod (although it does charge), is stuck in the glove box and is locked up and can only be controlled through the steering wheel. On that score, the steering wheel controls aren't very intutitive and making changes on the go is a bit of a recipe for a wreck. Once it is running, it is great, but making DJ adjustments on the go is difficult -- and the passenger is left out. The passenger can't really see the screen and definitely can't pick the music. I don't understand why they can't make the dash screen info and steering controls show up on the COMAND unit for either person to access and see.
Considering that is the biggest complaint we have so far with our new 06 ML350, I can't complain. but it seems so obvious that barring a technical impossibility, i can't believe MB didn't make it work through the COMAND.
Old 07-06-2005, 06:57 AM
HakkinenL's Avatar
2009 C200K
Hi NORTH 44 C55, how do you order the kit from Germany?
I own a 2005 C230K with Audio 20, does this kit with for my car?
Thanks!
Old 07-06-2005, 10:56 AM
according to Wolfgang
ordered thru MNG on the MBCanada forum
Old 07-06-2005, 11:11 AM
HakkinenL's Avatar
2009 C200K
Thanks. Looking at how to contact him now.
Have you managed to get yours hook up already?
Old 07-06-2005, 10:54 PM
hopefully tomorrow
hopefully tomorrow
Old 07-07-2005, 08:02 PM
installed
see c55 forum for pics
Old 07-07-2005, 08:50 PM
gmdebruyn's Avatar
saw some of your pics on the C55 forum. could you post some more please?
1) pic of ipod in your glovebox
2) pic of any pertinent ipod screens on steering console or elsewhere
thanks man. we're all jealous that you have yours already.
Quick Reply: Ipod hookup from Mecedes ?? What Happened .
