Sponsored by: Innova
COMAND info needed [from hidden menus]
Old Jun 30, 2002 | 07:44 PM
Richard's Avatar
2004 SL55, 2015 A250d, 2016 GLC250d
Hi
Could a couple of you guys in the US please do this for me on your COMAND screens ...
Enter the hidden menu diagnostic mode :-
Select AUX input [hit SYS button, select AUX] [dont need this on S/CL class]
Hold down MUTE, 1 and 3 buttons all together for 5 seconds
Once in diagnostic mode,
Select configurations, (using right hand rotary knob)
And tell me everything you see on that screen,
Ie, what is ticked, what is not ticked, and what the 3 numbers of
CFG are at the bottom left of the screen.
Can you also tell me what car, and what model year its in ?
Im working out how the CFG values relate to what is enabled on the system, and therefore how to make my "free" car diagnostic suite able to program the COMAND system to turn on TV stuff in the latest US cars.
Thanks !
R
Old Jul 2, 2002 | 05:06 PM
gareeb's Avatar
a car
Hey Richard I would help you but I have the German Unit.
I take it you are looking for the US units only right?
Old Jul 2, 2002 | 05:11 PM
Richard's Avatar
Ok, can you post your german info aswell ? If you could also post the s/w version, which can be found by looking in the software versions menu, in processors, near the bottom
Thank you !
Richard
Old Jul 2, 2002 | 05:18 PM
gareeb's Avatar
a car
WIll do right now BRB
Old Jul 2, 2002 | 05:37 PM
gareeb's Avatar
a car
Configuration info
TV
x Telephone
x Telematic
x Telematic Via DB2
x Analogous Bose
CFG.: A2 CD 08 Radimpuls : 30
Software version info
SW Version = REL__V13.06
OMS_EU_R
Old Jul 2, 2002 | 10:57 PM
yukpo's Avatar
2002 C320
Here is my configuration info (Euro).
V TV Tuner
V Telephone (Expand)
V Telematic
V Via Telephone Via D2B
_ Analogous Bose
CFG.:21 CD07 Radimpuls:30
Why don't I see check mark on "Analogous Bose", since I have Bose in my car??
Old Jul 3, 2002 | 03:02 AM
Richard's Avatar
V TV Tuner
V Telematic
_ Analogous Bose
You have a C (203) class, and that has digital bose (not analogue bose). Digital bose connects via the D2B fibre optic ring. Analogue takes the speaker outputs (and setting analogue bose changes the amplituded of those outputs and matches them to the analog bose amp)
Cheers
R
Old Jul 3, 2002 | 03:10 AM
yukpo's Avatar
2002 C320
thanks
Old Jul 5, 2002 | 03:18 PM
newMBz's Avatar
2002 C320 c2/c3/c4 & command
Richard, here is the info you needed. My car is 2002 C320 with US command system with Bose. And I took the car in Oct. 5 2001
TV Tunner
x Telephone (expand)
x Star Guide OBUR
Star Guide DRG
analogous BOSE
cfg: 22 4d 04 Radimplus: _ _
SW-Version REL_V06.11
Hope this info will help and let me know if you need any help from me.
By the way, Richard, I also see a DIAG Erros and it showed
SAE Code Type Cnt State
B1780 0x0000 002 P
What is that means. Please tell me if you know. Recently, I have a bad Alternlator replaced. And it makes me feel that the Quality of MB is not up to what I expected...
Old Jul 5, 2002 | 03:22 PM
Richard's Avatar
Most diag errors dont tend to be important, and in fact many dont even get logged to the dealer's diagnostic machine
That one means fault in can communication with cluster, and its only happened 2 times, probably as was trying to communicate as the starter was cranking etc.
You can clear the error list by holding mute and 0 together
Thank you for the other info !!
Richard
Old Jul 8, 2002 | 06:47 PM
Nav-TV's Avatar
Chevy Tahoe
one more....
here richard, one more, comand 2.0, no TV:
_ TV Tuner
v Telephone (Expand)
v Star guide OBUR
_ Star guide DRG
v Analogous Bose
v combi self aligned
CFG.:A2 6D 04 Radimpuls:30
MONI
PS very wierd: after intalling the TV Tuner, the Tv menu is in german and not in english. Everything else is in english. tried all the setting on the STAR with no luck! any ideas?
When I have installed the same tv tuner on a 2.5 german comand system, it showed the tv menu in english....
Old Jul 8, 2002 | 07:14 PM
Ted Baldwin's Avatar
300ce
you can go into the tv tunner menu itself, by pressing the right hand knob of the command inward and select the country you are in. It should change it to menu's to English.
Ted
Old Jul 8, 2002 | 07:17 PM
Nav-TV's Avatar
Chevy Tahoe
Ted, both "NORTH AMERICA" and "UNITED KINGDOM" would not make a difference.... the same problem with both comand 2.0 and 2.5......
Old Jul 9, 2002 | 04:18 PM
300ce
.........that indeed is wierd.
Ted
Old Jul 9, 2002 | 04:55 PM
Richard's Avatar
I imagine the TV tuner is coded with the wrong country in it [even with that very strange behaviour]
- it may be the "default language for COMAND" coding, or there may be one for the TV tuner itself (which is seperately programmed by Star Diagnosis using the COMAND unit as a gateway to the TV tuner
So I suspect a trip to a dealer with Star diagnosis to configure it is probably needed ...
Cheers
Richard
Old Jul 10, 2002 | 02:38 PM
E55MKB's Avatar
96 P993T, 00 E55, 09 SL63
comand 2.0, no TV (US version)
_ TV Tuner
_ Telephone (Expand)
_ Star guide OBUR
_ Star guide DRG
v Analogous Bose
_ combi self aligned
CFG.:A0 0D 04 Radimpuls: --
Car is 2000 E55 US version
Command unit was replaced with a brand new unit in 2002 since dealer was unable to upload newer updated software on the older unit.
Old Jul 10, 2002 | 02:55 PM
Richard's Avatar
E55MKB, do you have the phone installed ? If so, your dealer didnt code your unit correctly ..
Thank you !!
Old Jul 10, 2002 | 05:51 PM
E55MKB's Avatar
No phone
Richard:
I have no MB phone installed on my 00E55. Not worth it
Old Jul 11, 2002 | 11:13 AM
newMBz's Avatar
Richard, I noticed that other people from US has this
_combi self aligned
in their diagnostic menu. But mine doesn't have this item. Can you tell me what is that mean and why I don't have it. Thanks !!
Old Jul 12, 2002 | 01:47 PM
Richard's Avatar
That menu item started being displayed for mY2002 (or maybee MY2001) I think. The configuration item in star diagnosis that turns it on/off has always been there I think ....
Its actually "Instrument Cluster with self centering text"
If the text isnt properly centered in your phone/nav display then it needs the setting changed.
I know my CLK (MY2000) didnt have the self centering text, so this item was off. The MY2003 SL also doenst have self centering text.
Im not sure what vehicle has self centerintext, I guess there is one or two !
Richard
Old Jul 13, 2002 | 12:03 AM
newMBz's Avatar
Richard, got it and thanks for your reply !!
Old May 17, 2004 | 10:15 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Richard or newMBz,
Can I get it too. I need it for a project.
My configuration is also
Old May 18, 2004 | 05:59 AM
Richard's Avatar
Originally posted by Lenin
Richard or newMBz,
Lenin, I cant quite work out what you want
Cheers
Richard
Old May 18, 2004 | 07:52 AM
Lenin's Avatar
Richard,
I'm working on a freediag project and need some help with changing COMAND configuration related to TV. I hope you can help.
Old May 19, 2004 | 12:04 PM
Sl500z's Avatar
I just got a 2004 SL500. Here's my info:
_ TV-Tuner
X Telephone full exp.
X Star Guide OBUR
_ Star Guide DRG
_ analogous sound
_ Satellite Radio
CFG.: 22 4D 04 Ramimpuls: 30
I also have a ODB II Scantool, and I am willing to experiment. Let me know if I can be of any more help. I ordered a Dietz AV Interface and would like to activate the TV (now SAT) button to connect remote video to the COMAND screen.:p
