installing a aftermarket radio
does anyone have information on how to install a aftermarket radio in a 2002 e class, i need all the wire color codes and step by step instructions on how to take apart the center conusel.
1979 911SC, 2001 E55, 1999 CLK430, 1993 190E 2.6
Go get a VW harness and swap the constant and ignition wires. You will also need an antenna adapter. You will also need some german radio removal tools to remove the radio, that can be found in some autozones.
I need step by step instructions on how to remove the center counsel and the center dash. I do not want to break any clips. Can anyone walk me through the process, complete illustration will help. Thanks.
Administrator
I merged both of your threads. Lets not start another on the same subject.
Stff because this issue has come up numerous times. In addition you will get your answer faster than waiting for a post reply.
