Sponsored by: Innova
CD Changer Question
Old Dec 18, 2005 | 08:36 PM
BigBadVR4's Avatar
CD Changer Question
I have a 2002 CLK Cab, and it doesn't have a cd changer. I know some are in the glovebox, and some in the trunk. Where is the one located for this model? Also, are there any aftermarket ones that play mp3's that I could buy and mount in the glovebox.
Old Dec 18, 2005 | 11:06 PM
Jayhawk's Avatar
S500/W220/2000
I can't tell you about that particular model, but there are numerous threads on this forum and others dealing w/ exactly that type of issue. You might do a search on CD changer and CLK. It will probably produce more info than what you will get here.
Old Dec 19, 2005 | 06:34 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
The phone bulletin for your car on Paul's website at http://home.earthlink.net/~phdwebsit..._bulletins.htm should show you where it goes.
You may be able to add an aftermarket unit but you will not be able to integrate it easily. Your CD changer is designed to operate on your fiber optic bus. Do the search recommended - lots of discussion already for D2B fiber optics.
