S class center dash speaker removal procedure neededd
I have a 2000 s class which in the center of the dash near the defroster vents is a small speaker which is blown does anyone know how to remove this speaker
1 Post
Debadged 6-Speed '05 C320 Sports Coupe
Most of the time these are held in by spring clips. So, using a flat tool, like a putty knife or a plastic wedge, will permit this to pop off. A screwdriver should NOT be used as it will leave indentations in the surface.
Usually, prior to replacement , I coat the clips with white lithium grease, to make future removal easier.
