MB Bluetooth is finally here in US and available
#176
2005 S500 4-Matic, 1978 450SL
Originally Posted by kyles S500
I tried to order the puck from AWS today. Kim told me that my RZR V3 did not have the correct software version. My question is if I go ahead and by the puck will my phone work with it. I would assume so. The phone is only 4 months old. Has anyone had any experience with an unapproved phone on the bluetooth puck from AWS?
#177
2002 S500
Thanks for everyones help. If you need to change your S/W version go to http://www.planetmotox.net/monster_packs.php and select S/W version: R374_G_OE.42.09R_MOTOX.shx It is the 2nd on the list. Download this into comp. Then go to http://motox.info/showthread.php?t=5747 and follow the directions on how to load it onto your RAZR. This version is the US approved version that AWS told me I needed and would have to buy a phone from them. If you have an older RAZR this will also upgrade your phone with a newer software version.
Other useful downloads are located on this page http://www.motox.info/showthread.php?t=13796
You will also need to download RSD Lite and can get that from here http://en.soft4gsm.com
Hope this is helpful and saves you the $350.00 for the new phone.
#179
C240 2002
Originally Posted by carpersn
Just got off the phone with AWS (I found their #)...in ANY Mercedes which already has the hands-free system, AS LONG AS IT IS AT LEAST A DIGITAL Startac, then their are two steps to follow:
1) Upgrade to the V60 cradle
2) purchase the bluetooth dongle from AWS when it arrives sometime this 1st Q. She says they are building for inventory now.
WOOHOO!
WOOHOO!
Please advise.
Dick Gleason
#180
2006 C280
Originally Posted by Mr Papa
That makes AT LEAST two of us wating for the MOST version...
Mr Papa
Mr Papa
#181
Originally Posted by rgleason
Do you mean that you can add a V60 cradle to a Timeport system and it will work with the PUCK?
Please advise.
Dick Gleason
Please advise.
Dick Gleason
#184
Originally Posted by MagicO309D
Just make sure your PSE has a blue part number label. If it does, It'll work. If not, you'll need to replace your PSE with one of the newer versions.
You are 100% correct. I had to buy a new PSE(newest with blue label) for my 2002 E55 in order for the BT puck to work.
John
#185
#186
I am confused now.
I was initially under the impression the bt puck for v60 is only for the d2b system. however just got off the phone with aws and they confirmed that it will work with MOST (ie 04 w220) as long as you have a v60 cradle. he wasn't sure but he did ask someone who confirmed it. is this true? so it would work for 03-04 E and 04 S classes?
#188
Whichever one is available (1 of 5)
Originally Posted by superflysocal
I am confused now.
I am using the puck on my Motorola PEBL.
#189
Can anyone confirm if the BT systems are the same regardless of which MB class.
i.e. can I assume that the BT system on the S-class will work the same as the BT system on the E-class? I called my dealer and he has BT on some S-class models. I want to visit my dealer and demo my phone with a BT system to test compatibility before ordering one for my car (an E-class).
#190
The only exceptions are M-Class (MY '05), G-Class, SLR. These vehicles still use the older V60 compatible systems.
#191
I am confused now.
#192
The MHI system and Bluetooth Interface Module are the same for all cars from MY 2005 to present, dealer and MY 2007 factroy installed systems alike.
#193
Great. I'm going to try to test my phone tomorrow in an S-class and I'll report back the results for a Nokia 6682 (Symbian OS).
Don't forget to have someone call you while you're already in a call to see how your phone's Bluetooth link reacts. It's one of the more common issues that stresses the link. Try accessing voicemail. If your phone downloads it's phonebook, try making a call during the download as an added stress test.
Good Luck!
#194
You'll likely be able to test it in an '07 E-Class too since the '07 E's have been shipping for about 2 weeks now. Just ask to see an E with P1 package or up. They're equipped with hands-free from the factory now too!
Good Luck!
Good Luck!
#195
C240 2002
Not necessarily true!
Originally Posted by Skylaw
That is what it means.
Dick Gleason
#196
Yes. As long as the car has a V60 coil-cord cradle, the Puck (V60 Bluetooth Cradle Adaptor) will work plug-and-play. This includes cars with D2b and MOST bus.
ok, but is it the same bt puck for both systems? i have a d2b and a MOST car, both with v60 cradle.... i would like to interchange between them.
if not, then what are the two mercedes part numbers for each system?
#197
I have looked into this a bit further. Adding a V60 cradle and then adding a BT puck will only work if one has the autosensing PSE (Q682-0754 (V60 & Timeport "auto sense")). The puck emulates the V60 phone so if one is using a Q682-0648 (Timeport) or Q682-9648 (Timeport) PSE, a V60 bt adapter won't work with that PSE. My assumption is that the V60 PSEs will also work with the puck, e.g., Q682-0845 (V60) or Q682-0886 (V60).
Dick Gleason
Dick Gleason
How sure are you about your source?
#198
There is only one Puck (V60 Bluetooth Cradle Adaptor, B67875856). It works with all cars that have a functioning V60 phone system with V60 cradle installed.
Cars with StarTAC systems require V60 cradle and new V60 PSE.
Cars with Timeport will need a V60 cradle and may need a V60 compatible PSE (newer PSE was phased into production during the Timeport run). There is no VIN cutoff for the change so one must look at the PSE and see if it has a blue part number label. If white, it needs to be exchanged with a blue one.
#199
C240 2002
This contradicts what was mentioned earlier about any system with a startac or higher system would work if a v60 cradle is installed.
Mercedes PSEs (for Timeports and V60s) work with one phone or the other, unless you have the "blue tagged" PSE. See some data borrowed from Mik's website (Mikbox.com) below:
"Following PSEs are currently supported [these work with the Mikbox, but you need a different Mikbox for use with different PSEs]:
- Q682-0460 (StarTac)
- Q682-9460 (StarTac)
- Q682-0648 (Timeport)
- Q682-9648 (Timeport)
- Q682-0754 (V60 & Timeport "auto sense")
- Q682-0845 (V60)
- Q682-0886 (V60)"
The "auto sense PSE is the one they call "blue tagged."
If my information is accurate, the puck emulates the V60 but not the Startac or the Timeport. Can anyone else confirm this?
Dick Gleason
#200
You're spot on, Puck only works with PSE's that are compatible with V60. If you've got a functioning V60 hands-free system and want Bluetooth and a new handset, the Puck upgrade is a no brainer.
There is also a cool new version of the Puck on the way, code name "Puck with Tail", that will make owners of MY 2004 S-Class and MY 2003-2004 E-Class owners very happy. If you have one of these cars without a phone system, just add "Puck with tail" to get a fully integrated hands-free solution. This is possible because hands-free phone functionallity was built into the CP211 communications platform (specific Teleaid Box) included in every one of these cars at the factory. This new Puck has a leadout that simply plugs into the cradle connector tucked under the center console floor, no other hardware needed! The bad news is that it is not expected until about October this year.
