Radio installation w203, need some help
Hi! I have installed a Audio 10 CD in a 2002 w203, but I canīt get the steering wheel functions to work. I suppose there should be 3 DIN (?) plugs in addition to the antenna, but I only found 2 in my dash, one I guess goes to the speakers, the other supply power and perhaps some other controls.
So my guess is that the 3rd plug controls the steering wheel functions...
Does anyone have any knowledge on this?
Thanks! Jm
Thanks! Jm
2004 SL55, 2015 A250d, 2016 GLC250d
I'm sort of surprised its not there (dropped down the back somewhere) - what was in there before the Audio-10 ??
On car's with COMAND that loom is replaced with one for COMAND - so maybee sometimes they dont fit it at all :-(
Richard
Cable Harness, Radio Chamber C for Audio-10/30/30-APS
Part number A203 540 08 09
which needs to be ordered with "ES1" code up to ident A535915/F433730 and with "ES1 98" after that
- The picture has a D2B wakeup connecor, a CD power connector, a CANbus connector, a fusebox connector -
Chamber C , I guess, is the C connector that you are missing !
Theres also the CD changer power lead, A203 540 32 34 - I dont know how that interacts with the above part number, because that would normally connect to the C plug as-well
Hope that helps a bit
Richard
Hi and thanks for your help!
This car has been a police car in its former life, and has had a police radio installed instead of a normal radio. Iīll dig down there some more, and see what I can figure out.
But basically the connection Iīm missing goes from behind the speedometer console somewhere to the radio, it that correct?
Thanks again!
Thanks again!
R
I got the cable you mentioned, and today I literally took the entire car apart without finding a CANBUS distributor.
But what you are saying is that if I look by the footwells I will find a CANBUS distributor hopefully with an empty slot. Are there several of these around in the car or only one? And is it located alone or are there a bunch of cables near it?
One day I will make this work and it will all be worth it! Thanks again! Jm
Hah! I found it and plugged it and it works! The disrtibutor was by the passenger front door mount sort of, down there...
So now the radio illumination works fine and I can control the volume from the steering wheel.
However, I canīt get the other radion functions to work from steering wheel, there is no radio options in the system. Does this need to be programmed by a diagnosis system, or should they pop up by themselves.
Or are there more cables that need to be plugged into somewhere?
Thanks again! Jm
Thanks again! Jm
Yup, the cluster needs to be coded by the dealer to tell it there is an Audio system present, then you will get the menus - nothing else to plug in
Cheers
R
Cheers
R
