Sponsored by: Innova
CLK bluetooth suggestion
Old May 31, 2006 | 11:25 PM
MagicO309D's Avatar
It's not feasible to upgrade the headunit (assuming of course, that you're not Bill Gates)!
The download is not alphabetical, it's by memory location. You're phone can sort entries by alphabetically and so can the car once the memory is loaded.
The download proceeds by actual memory location. If you check you phone's entries, you should see the memory location listed for each entry. In other words, Albert may be at location 200 but Alfred may be stored at location 10. In this case, only Alfred will make it into your head unit.
Does this seem to apply to your results?
Old Jun 2, 2006 | 07:41 PM
cristo's Avatar
so how do I change memory locations on my phone without re-entereing all numbers/info ?
