Sponsored by: Innova
BT Echo
Old Jun 23, 2006 | 09:31 AM
Mdull's Avatar
2002 E55
BT Echo
Anyone care to take a shot at diagnosing this one??
02 E55 w/ UHI
MHI BT cradle
Razr or Q phone
From time to time the other party on the call comments that they are hearing an echo on their end. It has done it in my car with both phones, but never in the wifes car with either phone which is an 05 CLK 500 w/ MHI phone system.
Thanks for the thoughts
Old Jun 23, 2006 | 11:39 PM
MagicO309D's Avatar
Easiest thing to try is lowereing the audio volume level in your car during the call and ask if it helps.
Old Jun 24, 2006 | 06:53 PM
asg's Avatar
asg
2007 S600
It could be the phone service. My phone does this from time to time, even with out the bluetooth.
Turn off the phone and remove the battery for a few minutes and then try it again.
Old Jun 26, 2006 | 06:31 PM
Mdull's Avatar
2002 E55
Thanks guys I will give it a try. Am waiting for a V60 cradle and puck and am hoping it performs better with the Q phone. Results with the MHI cradle have been less than impressive for audio quality.
Old Jun 26, 2006 | 07:38 PM
MagicO309D's Avatar
I've also had the issue that asg describes above, try the hard reset too. When did you buy your MHI BT Module? There was a new software level upgrade round-about April that helps CDMA phone audio.
Old Jun 27, 2006 | 09:17 PM
Mdull's Avatar
2002 E55
Magic check your PM. Got the puck and cradle today but cannot get it to power up??? Thanks
Matt
Old Jun 27, 2006 | 10:59 PM
jameskk's Avatar
after much debate, I broke down and purchased the Argos BT today for $699. It will be installed in my 2002 S500. I plan to use it with my Moto Q.
Has anyone used the Argos with the Q yet?
Old Jun 28, 2006 | 02:56 PM
MagicO309D's Avatar
Q works with retrofit Puck but has still some issues with the MHI Bluetooth adaptor for MY 2005 and newer cars.
One hint for anyone getting bugs when using smart phones with Bluetooth sytems: Close all running applications.
Another hint for all non-certified phones: Do not dial or make a call untill phonebook download is complete. You can't control incomming calls but you can limit sync issues by not making calls.
