Installing COMAND in ML-430
Dont use the E class unit. You need the mounting clips that are only present on the ML and CLK units. It is far better to start with a ML unit.
A ML unit starts with part num. A163 820, the CLK with A208 820 ....
You also need a relatively new unit (or have a s/w upgrade done, with the latest software by your dealer) so the unit understands how to behave in a ML when it its coded by the dealer.
All you need is the aerial for the roof, an adapter cable (standard Mercedes part) and the COMAND unit - you should buy the rear-support bracket for the COMAND aswell.
- Plug it all in and have the dealer code the unit for the correct vehicle type and for whatever accessories you have attached (CD, phone, Bose etc).
PM me your email address, and I'll send you my incomplete document that tells you all the parts etc
Richard
