Sponsored by: Innova
Sl Sound Improvement
Old Sep 22, 2006 | 11:15 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i would like to improve the fullness of sound at low volume in the sl. is there a simple plug n play improvement to boost low end sound fullness of the existing unit?
thanks
Old Sep 22, 2006 | 01:09 PM
MagicO309D's Avatar
SL audio modifications are difficult from both electronic and space limitation perspectives. The only simple DIY SL sound modification is to readjust base and treble settings to see if you can come up with something more to your liking. I can't remember if your car has it but if you have Logic7, also try switching the Logic7 mode to standard mode. You may like this setting better because the sound is not over-processed.
If you want to do more than that, it's best to visit a few custom audio shops in your area. They'll probably suggest larger door mounted LF drivers and/or a replacement custom subwoofer enclosure. This will give you the ability to increase bass response at low levels that will not distort at higher volume levels.
