Parts for adding integrated Nokia 6310i
2004 SL55, 2015 A250d, 2016 GLC250d
Originally posted by peralex
BTW what is that unit above motorola control unit?
I suspect that motorola unit is the Teleaid.
Is that a 25 way D-type or a 15-way. To me it looks like the 15way D-Type that is used for VCS (voice recognition).
The 4 pin plug looks like the anntenna compensator for the phone's power lead. The aerial cables either loop thru there, or go to teleaid. - can you do me a close up of the aerial connectors - they look different to Europe.
I suspect theres a 25way D-type under there somewhere.
I will try findout out more info aswell !
Cheers
R
C240 2002
Re: Re: Part Number, Prices and Potential Source
Originally posted by funky102
I feel like a group buy coming up. Anyone else interested?
Dick
This is close up of aerial and 4 pin plug behind passenger seat of ML 500 2002 US
Looks like theres another aerial connector hidden in the loom aswell - Im going to assume that goes off to the front of the car ..
So, in order to use it for the phone you need the aerial spiltter/combiner, that will sit between the two cables that are connected together already (one to car aerial, one to teleaid), and allow you to connect the phone aswell.
I dont know that part number, and the cable connectors are different to Europe, so you'll have to buy that in the US. The dealer will have the part number for that,
The other cables i expect to be there arent visible - namely the D2B fibre optic (may be plugged inyo the front of the teleaid unit) and the 10pin RJ45 that extends the phone cable.
Of course, those two may not be fitted into the ML as standard for US markets, because the phone will end up in the centre console so the cable is short ...
Cheers
R
BTW, the part number for that Motorola unit is A220 820 21 85 and the orange label warns you that the unit is vehicle specific.
Can you try looking under the plate that it all mounts on (best done from the front of the car, (slide out the storage draw and press on the clip on one side of it to release fully if you have it)
and see if there are anyother connectors that you can see.
Im looking for a 25way dtype with a grey shell with two wings that clip it onto the standard nokia control unit. (rather than one with screws that hold it onto the motorol unit)
R
#32
ML500
There is another aerial connection which is not used for anything. This is close up of that aerial connector. I will recheck how many pins D-sub connector has sometime today. Do EU ML's have Tele-aid as well? If yes is location of Tele-aid is Identical to ours? Is it possible that Tele-aid unit is a part of Motorola handsfree installation?
#33
ML500
I did not find any other aerial(other than one on close up), but I found fiberoptic cable going to the Motorola unit. I could not really see it (meaning see where it is going) but I could disconnect it and reconnect. Is tele-aid suppose to have fiber optics? And as far as aerial goes - there is one plugged in one and one without connection - seems like it would not have any other use other than going to the phone. This is a close up of that spare connector.
#34
European Teleaid has a full blown phone built into it (and a GPS receiver) - I dont know how the US teleaid works. My gut feel says they could have made that act as the telephone - but they dont because they can charge more money :-) and it would be complicated with billing
#35
C240 2002
Location in 2002 C240 Phone Pre-Wiring
Here is a picture of the phone pre-wiring in my trunk. It is located behind the right wall panel between the rear wheel well and the rear light. Notice the annotation to identify the connections.
If any of you are looking for the wiring in your own car, that's where it is.
Dick
Dick
#36
ML500
I beleive that our (US) Tele-Aid is built same way, meaning that it works just like cell phone. First year MB allow you to use 30 minutes in a year free and no yearly subscription. After first year subscription is $240 plus mintutes on top of that, which means whoever carrier is (Verizon, AT&T or anybody else) I am sure their bill is well covered by MB Tele-Aid users. As far as being a full blown phone - I do not know but certainly sounded like one and uses same hardware the installed phone does (Mike and speaker).
#37
If its using the same speaker (ie the car's speakers) then that is why it connects to the D2B bus (fibre ring), so it can talk to the COMAND/Amp to connect it to the speakers
R
#38
Re: Location in 2002 C240 Phone Pre-Wiring
Dick
Dick
Perfect. The grey wings on the 25 way D-type clip into the Nokia phone support electronics. The 4 way connector (which should have 3 wires in it) is the power for the compensator/booster (+12, Gnd, switch-on).
I presume the aerial lead that goes to the bumper is connected to another aerial lead that goes to teleaid. (and therefore have the wrong connectors to connect to the european GSM1800 booster) (the european ones have tiny connectors with black clips, the US ones seem to have screw on ones that are just under half inch in diameter)
So, you do need a mounting plate, and the antenna switch/splitter.
Cheers
R
#40
C240 2002
Re: Re: Location in 2002 C240 Phone Pre-Wiring
Cheers
R
Cheers
R
Thanks,
Dick
#41
C240 2002
Any suggestions will be appreciated.
Dick
#42
Re: Re: Re: Location in 2002 C240 Phone Pre-Wiring
Richard, would you mind doing me a favor and seeing if there is a European part number for this mounting plate? Also, I wonder if it might be possible to use a two way splitter like they make for television cabling rather than the stock splitter, do you think?
Thanks,
Dick
Thanks,
Dick
(you could infact move the wiring to the centre compartment, I imagine its the correct length to do that and will save you making a bracket, I have a diagram that I will email you)
The splitter isnt a splitter, its a "switch" - that web site I sent you has the US part number for it .... I would use the right part - primarily because telaid uses the aerial - and i think they are tuned to the mobile frequency (as that web site shows two important bits of info (a) theres different parts for dual-band and (b) you dont use this if you dont have teleaid)
I will find out if there is a EU equivalent !!
Cheers
R
#43
C240 2002
Re: Re: Re: Re: Location in 2002 C240 Phone Pre-Wiring
Hi, there isnt a european part, because they dont put it there in Europe, they put it in that centre compartment
Cheers
R
Cheers
R
Thanks again,
Dick
#44
C240 2002
Re: Parts for adding integrated Nokia 6310i
Hi
In Europe we have Nokia 6310i as integrated phone now ...[to]retrofit or upgrade this to your car, INCLUDING US cars, you need :-
Wiring loom - depends on car, not needed on US cars (pre-wired), or on cars with existing Nokia 6150 installation.
Control Unit A203 820 25 85 (do not buy 203 820 99 26 as it wont work with 6310/6310i)
Resistive/DC filter A203 820 55 15
E-Net compensator (GSM1800 booster), A203 820 39 26
...Then you need the cradle. Your dealer should be able to find the parts, but for instance: -
C (W203) with phone in center console glovebox :-
Bracket A203 820 06 51
Clip A203 823 00 60
Cover A203 823 03 49 (covers cables)
2*Screws A140 990 06 22
Cable (probably not needed for USA) - see dealer
Hi
Clip A203 823 00 60
Thanks,
Dick
#46
ML500
Hi, Richard. I installed Ericsson T68i in my ML500 and while doing that I noticed rj-45 like connector (male) and two aerial connectors behind center console. Is that a connection for the phone? I could not find any of 25-pin D-type connectors anywhere else. Thanks
#47
Yes. On European cars, the other end of those cables are under the front right hand seat, where the phone electronics will plug in
- Im not quite sure if thats where they go on US cars ..
R
R
#48
C240 2002
Phone tie-in to D2B
R
R
Also, any idea where in the UK I could get a reasonably priced Nokia 6310i? I tired to buy one on ebay, but the seller took my money and didn't deliver.
Thanks,
Dick
#49
Re: Phone tie-in to D2B
Hi
I think they'll be up by the head unit ... but I really have no idea .. you could ask your friendly US dealer :-)
-Its probably worth removing the panel above passenger footwell and seeing if theres anything obvious - its much simpler then the headunit ..
6310i. 185+VAT (sim-free (ie without contract) on www.expansys.com - they should not charge you the VAT if you have them ship directly to the USA
- Im sort of surprised by the ebayer. perhaps you can use the ebay buyer protection to get 90% back ?
Cheers
R
Cheers
R
#50
C240 2002
Re: Re: Phone tie-in to D2B
R
R
He had over 100 positive feedback comments, no negatives at the point I purchased from him. Should see all the negatives now!
Dick
