Sponsored by: Innova
Simple Q: Does D2B CD changer require programming?
Old Sep 6, 2002 | 08:59 AM
RA71325's Avatar
I just bought an MB/Alpine cd changer for my 2002 C320 and the seller (an MB tech) says that, unless the car has had a changer before, a reprogramming by the dealer is needed to have it recognized. However, I had heard otherwise.
Is dealer programming required?
Old Sep 6, 2002 | 11:30 AM
Lynn's Avatar
It will need to be programmed eventually. Fault codes will build up until the changer stops working. Sometimes this takes months, but it happened to one person in a few daysl
Old Sep 6, 2002 | 12:40 PM
RA71325's Avatar
Thanks. That's what I needed to know.
Old Oct 10, 2002 | 07:32 PM
bhuang1103's Avatar
BMW528i 2000, Mercedes E320 SE 2002
I am trying to install an optical cd changer to a 2002 E320. Is the reprogramming necessary? I don't have command option. If necessary, is it easy that one can do it himself?
This is the first time I heard one has to reprogram HU for CD changer. I installed 4 cd changers before.....
Your advise is greatly appreciated.
Ben
Old Oct 10, 2002 | 08:32 PM
Lynn's Avatar
If the E is like the C, eventually you will need to have someone with a DAS computer program the D2B controller.
Old Oct 10, 2002 | 08:36 PM
bhuang1103's Avatar
Hi Lynn,
Thanks. How do I find out if E is like the C class?
Old Oct 10, 2002 | 08:47 PM
Lynn's Avatar
Try calling you service advisor at the dealer, or the the MBUSA customer assistance center at 1-800-FOR-MERC
Old Oct 18, 2002 | 02:28 AM
Cryptnotic's Avatar
It's been 9 months, and I haven't had any fault codes and I haven't had the changer stop working.
Old Oct 18, 2002 | 04:04 PM
sissi's Avatar
No HU of MB needs to be configured to get the functionality. But your dealer should do a DAS configuration of the D2B ring to make sure you will not get an additional error code.
